Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California ![]() |
ok... so my car has a new 911 front end. M calipers *new* turbo tie rods *new* ball joints etc. everything is NEW. i need to get it aligned.
go to a place that does JUST alignment and BRAKES. so here goes. I gave him the specs of what i wanted (previous alignmnet thread) camber caster and toe. he does the toe to 1/16th like spec's. says he cant do camber (something about raising one side, thinks he knows how the torsion bar system works [he doesnt] and and cant do caster too. says because car is lowered) . the car is running stock tires and is BARELY lowered up front. I believe he misadjusted the turbo tie rods. (he unscrewed them from the rack i believe and used the lock nut to hold the length. dont you have to take off the cotter pin, pop out the tierod end, and rotate the whole tie rod end? you cant unscrew the rack end can you? i pointed out to the where you adjust camber and caster (opened hood and ponted to the tops of the strut on the fender well!!!) so i have uneven left to right camber and caster, he didnt even do that. i got charged 25.00 for toe in adjustment. im gonna go yell at him and get my money back, if im right about how he adjusted the turbo tie rods. please respond ASAP so i can get back to this idiot! |
ArtechnikA |
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None ![]() |
QUOTE(acox914 @ May 5 2004, 01:10 PM) I believe he misadjusted the turbo tie rods. (he unscrewed them from the rack i believe and used the lock nut to hold the length. dont you have to take off the cotter pin, pop out the tierod end, and rotate the whole tie rod end? you cant unscrew the rack end can you? are you saying he removed the belly pan and adjusted them AT THE RACK? probably not... no, you do not remove tie rod ends from the steering arm to adjust them. you loosen the locknut and turn the rod. it's a turnbuckle, like antiroll bar droplinks... |
Lo-Fi Version | Time is now: 29th April 2025 - 09:20 PM |
