> Transmission input shaft seal mystery, have never seen this style seal-should I replace it?
reharvey
post Dec 15 2011, 11:26 AM
I have a low mileage 72 trans ( 6000mi. ) that I'm converting to a side shifter. It has a front seal that is very different from the one in the 74 trans that is being used for linkage parts. The black seal in the 74 trans is usually what is found on all the cases I've dismantled. . The sealing area on the blue 72 is inset much deeper into the case and the outer surface sits a machined area not used on the 74 black seal. I'm sure the 72 trans has never been apart so it's an original piece. So, should I knock it out and use the seal that is in the gasket set?
Also got to say that it's great to take a trans apart and see everything inside looks like new!
Richard Casto
post Dec 15 2011, 04:13 PM
Blue Sky Motorsports, LLC
Be careful to not scratch the bore in the case when you remove the seal. If the case is still apart you can tap it out from the inside. If the transmission is still together you can use a seal puller, or screw a small screw into the seal and use that to pull it out. Those seals fit tightly. I lubricate mine when I install them and as it's easy to tear them if you are not careful.
Richard
reharvey
post Dec 15 2011, 04:19 PM
QUOTE(Richard Casto @ Dec 15 2011, 05:13 PM) *
Richard
Thanks for the info. It is still apart and I'll pop the seal out from the inside. Will also lube it up before installing it. Thanks, Ray
- Lo-Fi Version Time is now: 27th December 2024 - 12:01 AM
