mrbubblehead |
Twodollardoug ![]() ![]() ![]() Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California ![]() |
i just wanted to start a thread to see what you guys do day to day on your cars.
i'll start, about a month ago, i pulled my engine and trans to put in a new clutch. had the flywheel lightened and resurfaced. but what i didnt know is that i had to shim the little ball that the clutch arm rides on, after a resurfacing. so guess what i did today? yup, pulled the trans and put an extra washer under the ball. you have to goop up both washers to get it to seal because the threaded hole goes all the way thru to the inside of the trans. i also replaced the plastic cup that the ball rides in. the throwout bearing and its little plastic blocks were fine so i buttoned every thing back up. 5 hours total. i think this has been the cheapest repair yet on my car. $2.75 for the little plastic cup. what did you do to your 914 today? |
stugray |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None ![]() |
Finished cleaning the last of my parts fro my Dual Weber rebuild in the ultra-sonic parts washer.
Touching up roll cage & reinstall after all new interior. Replaced seat rails with race adjustable & grade 8 bolts. Stripped & repainted the hellhole from PO's silicone mess. Repainting the rear firewall engine side. |
mrbubblehead |
Finished cleaning the last of my parts fro my Dual Weber rebuild in the ultra-sonic parts washer. Touching up roll cage & reinstall after all new interior. Replaced seat rails with race adjustable & grade 8 bolts. Stripped & repainted the hellhole from PO's silicone mess. Repainting the rear firewall engine side. what type of ultra sonic parts washer do you have? where did you get it? |
Lo-Fi Version | Time is now: 26th June 2024 - 09:06 AM |
