mrbubblehead |
Twodollardoug ![]() ![]() ![]() Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California ![]() |
i just wanted to start a thread to see what you guys do day to day on your cars.
i'll start, about a month ago, i pulled my engine and trans to put in a new clutch. had the flywheel lightened and resurfaced. but what i didnt know is that i had to shim the little ball that the clutch arm rides on, after a resurfacing. so guess what i did today? yup, pulled the trans and put an extra washer under the ball. you have to goop up both washers to get it to seal because the threaded hole goes all the way thru to the inside of the trans. i also replaced the plastic cup that the ball rides in. the throwout bearing and its little plastic blocks were fine so i buttoned every thing back up. 5 hours total. i think this has been the cheapest repair yet on my car. $2.75 for the little plastic cup. what did you do to your 914 today? |
mrbubblehead |
wow tradisrad, thats pretty crazy. luckily it happened in the driveway.
i was able to take my car out this morning on my 20 mile test loop. and it is shifting perfectly! (IMG:style_emoticons/default/driving.gif) YEAH! what a difference new bushings, new clutch disc, and an adjusted shifter makes. almost as smooth as one of my vws. i wonder if a cable shifter system would make it any better? or is this just the way the internals are designed? and its as good as its gonna get? |
Lo-Fi Version | Time is now: 25th June 2024 - 04:58 PM |
