aircooledtechguy |
The Aircooledtech Guy ![]() ![]() ![]() Group: Members Posts: 1,966 Joined: 8-November 08 From: Anacortes, WA Member No.: 9,730 Region Association: Pacific Northwest ![]() |
I've had a long term project going now to turn my '67 Squareback into my shop car. While I love driving my 914, it has limitations as a daily parts hauler. I love old styling with new technology and updates, so my goal is to turn my humble Square into the wagon that Porsche never made. I want it to drive and handle more like a Porsche than a VW wagon and it's got to be a true "Sleeper" (not a real problem; since it's a wagon). (IMG:style_emoticons/default/shades.gif)
(IMG:http://www.914world.com/bbs2/uploads_offsite/images.thesamba.com-9730-1324689630.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/images.thesamba.com-9730-1324689631.2.jpg) This has been a 4-5 phase project. Phase-1 - Convert it to Porsche 914 2.0L motor. Make it physically adapted to the car and running MS2 w/ Ford EDIS ignition. Get it tuned to be a daily driver. DONE!! (IMG:http://www.914world.com/bbs2/uploads_offsite/images.thesamba.com-9730-1324689631.3.jpg) Phase-2 - Make the motor look good and freshen it up with new P&Cs. The heads were freshened only about 2K miles before I got it, by me when it was in a clients 914 that he converted to Subie power. I noticed that once I had a few miles on it myself, it was using a bit of oil. So I upgraded to a new set of 96mm P&Cs. So now it's a 2056. ![]() ![]() I had my local powder coater do all the tins in black and the plenum and runners in grey for a stock look. I'm running T-4 H/Es with a modified bus header and a Summit Racing Flow Master clone muffler. So I had those ceramic coated in black so they are not attention grabbers from the back. This car is a sleeper (IMG:style_emoticons/default/happy11.gif) ![]() DONE!! Phase-3 - Convert the rear suspension to the later style IRS and install a Porsche 923 trans out of a Porsche 912E. The rear suspension is DONE!! While at it, I upgraded it with 914 rear brakes, urethane bushings, adjustable spring plates and a rear sway bar. (IMG:style_emoticons/default/driving.gif) (IMG:http://www.914world.com/bbs2/uploads_offsite/images.thesamba.com-9730-1324689632.4.jpg) Since the trans is taller than a stock 4-speed and cutting into the car can't happen due to rear seat issues. I gained the 1.5" I needed by spacing the body off the rear suspension with spacers. So here I sit, on the final leg of phase-3. I now need to couple the motor/trans and lift it into it's final place and fab rear engine hanger mounts for the rear bar. It's late and I'm tired. . . Phase-4 - Front suspension upgrade. Currently in-work Phase-5 - Paint so it doesn't look so crappy, though it does add to the "sleeper" persona. . . Stay tuned for more later. . . |
aircooledtechguy |
Made good progress today. Joined the motor and trans hopefully for the last time.
(IMG:http://www.914world.com/bbs2/uploads_offsite/images.thesamba.com-9730-1324767704.1.jpg) Lifted the car and got the motor and trans into position, then dropped the car onto the motor/trans. LIKE A GLOVE!! Then I had to design and fab a pair of rear hangers for the rear mount bar. The bar is a stock bus bar, so it's rubber mounted at the motor. So these are solid mounts to the car. The pic is 90degrees off, but you all get the idea. (IMG:http://www.914world.com/bbs2/uploads_offsite/images.thesamba.com-9730-1324767705.2.jpg) Once I bolted these up, the motor and trans was finally home; not hooked-up, but home in it's final location. (IMG:http://www.914world.com/bbs2/uploads_offsite/images.thesamba.com-9730-1324767706.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/images.thesamba.com-9730-1324767707.4.jpg) Things I have to re-engineer before I can close out phase-3 are: - The clutch cable. The stock one is about a foot too short now and I need a custom-made bowden tube. That should be interesting. . . I'm going to test fit a stock 914 cable assembly just to see how it does. . . - E-brake cables. Same issues as the clutch but found a company that makes cu$tom e-brake cable$. - Make new brake lines. This should be a snap. - Make a custom off-set shift coupler for the trans. Right now the shift rod is above the torsion housing and the trans shift shaft is below it. . . - Figure out what to do for a shifter. I think I already have this one done, but i don't want to jinx it. . . - Hook-up the EFI and all the wiring and fuel system. I lowered it down to see how it's riding and while it looks great, I may raise it up about an inch since it's almost riding on the bump-stops. (IMG:http://www.914world.com/bbs2/uploads_offsite/images.thesamba.com-9730-1324767707.5.jpg) Well time to START my Christmas shopping. . . (I do better under pressure) (IMG:style_emoticons/default/lol-2.gif) |
3d914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,275 Joined: 24-September 03 From: Benson, AZ Member No.: 1,191 Region Association: Southwest Region ![]() |
(IMG:http://www.914world.com/bbs2/uploads_offsite/images.thesamba.com-9730-1324767707.4.jpg) Well time to START my Christmas shopping. . . (I do better under pressure) (IMG:style_emoticons/default/lol-2.gif) Very cool wagon. I love sleepers. (IMG:style_emoticons/default/drooley.gif) What type of heat exchangers are those? This is a 2.0L right? |
Lo-Fi Version | Time is now: 26th June 2024 - 03:53 AM |
