> OT: Working on my shop car, The wagon Porsche never built. . .
aircooledtechguy
post Dec 23 2011, 07:20 PM
The Aircooledtech Guy
I've had a long term project going now to turn my '67 Squareback into my shop car. While I love driving my 914, it has limitations as a daily parts hauler. I love old styling with new technology and updates, so my goal is to turn my humble Square into the wagon that Porsche never made. I want it to drive and handle more like a Porsche than a VW wagon and it's got to be a true "Sleeper" (not a real problem; since it's a wagon). (IMG:style_emoticons/default/shades.gif)
(IMG:http://www.914world.com/bbs2/uploads_offsite/images.thesamba.com-9730-1324689630.1.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/images.thesamba.com-9730-1324689631.2.jpg)
This has been a 4-5 phase project.
Phase-1 - Convert it to Porsche 914 2.0L motor. Make it physically adapted to the car and running MS2 w/ Ford EDIS ignition. Get it tuned to be a daily driver. DONE!!
(IMG:http://www.914world.com/bbs2/uploads_offsite/images.thesamba.com-9730-1324689631.3.jpg)
Phase-2 - Make the motor look good and freshen it up with new P&Cs. The heads were freshened only about 2K miles before I got it, by me when it was in a clients 914 that he converted to Subie power. I noticed that once I had a few miles on it myself, it was using a bit of oil. So I upgraded to a new set of 96mm P&Cs. So now it's a 2056.
I had my local powder coater do all the tins in black and the plenum and runners in grey for a stock look. I'm running T-4 H/Es with a modified bus header and a Summit Racing Flow Master clone muffler. So I had those ceramic coated in black so they are not attention grabbers from the back. This car is a sleeper (IMG:style_emoticons/default/happy11.gif)
DONE!!
Phase-3 - Convert the rear suspension to the later style IRS and install a Porsche 923 trans out of a Porsche 912E. The rear suspension is DONE!! While at it, I upgraded it with 914 rear brakes, urethane bushings, adjustable spring plates and a rear sway bar. (IMG:style_emoticons/default/driving.gif)
(IMG:http://www.914world.com/bbs2/uploads_offsite/images.thesamba.com-9730-1324689632.4.jpg)
Since the trans is taller than a stock 4-speed and cutting into the car can't happen due to rear seat issues. I gained the 1.5" I needed by spacing the body off the rear suspension with spacers. So here I sit, on the final leg of phase-3. I now need to couple the motor/trans and lift it into it's final place and fab rear engine hanger mounts for the rear bar. It's late and I'm tired. . .
Phase-4 - Front suspension upgrade. Currently in-work
Phase-5 - Paint so it doesn't look so crappy, though it does add to the "sleeper" persona. . .
Stay tuned for more later. . .
aircooledtechguy
post Dec 24 2011, 05:01 PM
Made good progress today. Joined the motor and trans hopefully for the last time.
(IMG:http://www.914world.com/bbs2/uploads_offsite/images.thesamba.com-9730-1324767704.1.jpg)
Lifted the car and got the motor and trans into position, then dropped the car onto the motor/trans. LIKE A GLOVE!! Then I had to design and fab a pair of rear hangers for the rear mount bar. The bar is a stock bus bar, so it's rubber mounted at the motor. So these are solid mounts to the car. The pic is 90degrees off, but you all get the idea.
(IMG:http://www.914world.com/bbs2/uploads_offsite/images.thesamba.com-9730-1324767705.2.jpg)
Once I bolted these up, the motor and trans was finally home; not hooked-up, but home in it's final location.
(IMG:http://www.914world.com/bbs2/uploads_offsite/images.thesamba.com-9730-1324767706.3.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/images.thesamba.com-9730-1324767707.4.jpg)
Things I have to re-engineer before I can close out phase-3 are:
- The clutch cable. The stock one is about a foot too short now and I need a custom-made bowden tube. That should be interesting. . . I'm going to test fit a stock 914 cable assembly just to see how it does. . .
- E-brake cables. Same issues as the clutch but found a company that makes cu$tom e-brake cable$.
- Make new brake lines. This should be a snap.
- Make a custom off-set shift coupler for the trans. Right now the shift rod is above the torsion housing and the trans shift shaft is below it. . .
- Figure out what to do for a shifter. I think I already have this one done, but i don't want to jinx it. . .
- Hook-up the EFI and all the wiring and fuel system.
I lowered it down to see how it's riding and while it looks great, I may raise it up about an inch since it's almost riding on the bump-stops.
(IMG:http://www.914world.com/bbs2/uploads_offsite/images.thesamba.com-9730-1324767707.5.jpg)
Well time to START my Christmas shopping. . . (I do better under pressure) (IMG:style_emoticons/default/lol-2.gif)
smontanaro
post Dec 25 2011, 08:51 AM
QUOTE(aircooledtechguy @ Dec 24 2011, 05:01 PM) *
Would a hydraulic clutch be an easier option?
Cool project. I've been looking at Type 3s on The Samba off-and-on for a month or so. (I've owned a couple squarebacks but actually like notchbacks better.) Most of them have been so thoroughly thrashed that I wouldn't even think of buying one. (Maybe there is some parallel non-Samba universe where all the Type 3s are all perfect?)
S
aircooledtechguy   OT: Working on my shop car   Dec 23 2011, 07:20 PM
BajaXJ92   :drooley: Let me know if you ever want to sell i...   Dec 23 2011, 07:30 PM
JRust   Looks like a cool project! Can't wait to s...   Dec 23 2011, 07:47 PM
NORD   Very Cool Now Zebra paint job almost there The M...   Dec 23 2011, 07:48 PM
Krieger   I dig this car! You have to keep us posted.   Dec 23 2011, 07:56 PM
Tom_T   I've always loved those Squarebacks! Seve...   Dec 23 2011, 08:45 PM
phillstek   Looks great and can't wait to see it done (whi...   Dec 23 2011, 10:09 PM
rdauenhauer   :smash: :welder: :sawzall: :trophy:   Dec 23 2011, 10:56 PM
swood   subscribed! looking forward to the "how-t...   Dec 23 2011, 11:03 PM
9146986   Very cool project! That's one of my favor...   Dec 23 2011, 11:33 PM
mrbubblehead   too cool. ive never had a type 3. is it i window w...   Dec 24 2011, 12:48 AM
orange914   5 speed for freeway delivery... cool!   Dec 24 2011, 01:24 AM
aircooledtechguy   Made good progress today. Joined the motor and tr...   Dec 24 2011, 05:01 PM
3d914   http://www.914world.com/bbs2/uploads_offsite/ima...   Dec 24 2011, 05:12 PM
smontanaro   - The clutch cable. The stock one is about a foo...   Dec 25 2011, 08:51 AM
Jakeodoule   Very nice work Nate!   Dec 24 2011, 05:20 PM
Dr Evil   WANT! Mix that with rootwerks lifted monster ...   Dec 24 2011, 05:34 PM
Root_Werks   WANT! Mix that with rootwerks lifted monster...   Jan 12 2012, 10:29 AM
Dr Evil   Ya know, I see things like this and I want to move...   Dec 24 2011, 05:36 PM
rick 918-S   Nice project!   Dec 24 2011, 05:36 PM
aircooledtechguy   Thanks for the kind words guys. I've had this...   Dec 24 2011, 08:36 PM
Prospectfarms   ...The H/Es are from a VW 411/412. They are a v...   Feb 14 2012, 08:37 AM
Vacca Rabite   The T3 Wagons were my favorites of the aircooled V...   Dec 24 2011, 08:58 PM
Jacob   Great build! thanks for posting! :popcorn...   Dec 24 2011, 09:40 PM
PanelBilly   How about spraying the interior with a bed liner. ...   Dec 24 2011, 09:53 PM
Series9   :first: I love it. My first car was a Fastbac...   Dec 25 2011, 09:01 AM
barada   Awesome build. I bet some hand drawn logos on it w...   Dec 25 2011, 11:38 AM
rgalla9146   Awesome build. I bet some hand drawn logos on it ...   Dec 25 2011, 12:13 PM
aircooledtechguy   [ Trans looks like a 915 ... why 923 ? Great ide...   Dec 25 2011, 02:03 PM
aircooledtechguy   Made some progress this afternoon. Fabbed-up a cu...   Jan 11 2012, 09:36 PM
plymouth37   Great project! I have always loved these, nice...   Jan 12 2012, 08:51 AM
PeeGreen 914   This is a very cool SB. I've always liked them...   Jan 12 2012, 11:08 AM
aircooledtechguy   Pulled the motor and trans out to get the last pie...   Jan 14 2012, 04:56 PM
aircooledtechguy   I worked on the shift-shaft and coupling for the P...   Jan 17 2012, 12:02 PM
ChrisNPDrider   sweet :beer2:   Jan 17 2012, 03:34 PM
rdauenhauer   If the starter is in that close proximity to the h...   Jan 17 2012, 08:46 PM
aircooledtechguy   If the starter is in that close proximity to the ...   Jan 18 2012, 02:00 PM
smontanaro   It shouldn't be a problem since the 411/412 ca...   Jan 18 2012, 03:21 PM
majkos   Great thread! My first car was a '69 Squa...   Jan 18 2012, 08:13 PM
zymurgist   Great thread! My first car was a '69 Squ...   Jan 19 2012, 05:01 PM
rhodyguy   very cool nate. did you have to mount the fresh ai...   Jan 19 2012, 01:14 PM
aircooledtechguy   Awaiting parts on a bunch of stuff, due to all the...   Jan 19 2012, 04:35 PM
ottox914   Just checked this out- awesome project- keep the p...   Jan 19 2012, 05:14 PM
aircooledtechguy   Saturday I made some progress on the BA4 heater in...   Jan 22 2012, 11:09 PM
aircooledtechguy   A few days ago I got my custom clutch cable from t...   Feb 16 2012, 11:17 PM
Root_Werks   Dang Nate, you are an animal! Keep up the gre...   Feb 17 2012, 12:45 PM
strawman   Been watching this thread closely, as I've alw...   Feb 18 2012, 10:51 PM
arkitect   Been watching this thread closely, as I've al...   Feb 18 2012, 11:39 PM
aircooledtechguy   Congrats on the new project Geoff!! That...   Feb 20 2012, 06:30 PM
Bleyseng   Great project and good to see how you modernized i...   Feb 21 2012, 05:10 AM
aircooledtechguy   So over the past several weekends I have been work...   Feb 29 2012, 12:45 PM
Irish914   great project looks like lots of fun :Qarl:   Feb 29 2012, 02:46 PM
veltror   I do like this...   Feb 29 2012, 02:54 PM
Prospectfarms   Fascinating, but the difficulty of fabricating the...   Mar 1 2012, 12:31 AM
aircooledtechguy   Been spending my Saturdays of late, wrapping up al...   Mar 20 2012, 12:00 AM
rhodyguy   heat exchangers, gas fired heater, heated seats......   Mar 20 2012, 10:36 AM
aircooledtechguy   heat exchangers, gas fired heater, heated seats.....   Mar 20 2012, 01:21 PM
aircooledtechguy   Been sewing up details on the shop-car over the pa...   Apr 16 2012, 06:38 PM
aircooledtechguy   So I've logged about 60 miles on the Square si...   Apr 19 2012, 10:08 PM
kg6dxn   I run one of those hydraulic brakes. It will loose...   Apr 19 2012, 10:26 PM
aircooledtechguy   As I log more and more miles onto my shop car, I h...   Jun 20 2012, 02:55 PM
Jamie   Dangit, the guy can even make a custom fuel tank...   Jun 20 2012, 08:00 PM
Jakeodoule   Nice work Nate! really cool ride!   Jun 20 2012, 09:15 PM
aircooledtechguy   Thanks for the kind words guys; it's been a re...   Jul 9 2012, 04:37 PM
Mr.242   ARE you fricken kidding me? Nate...you've be...   Jul 9 2012, 09:07 PM
aircooledtechguy   I finally got the chance to install the new seats....   Jul 11 2012, 06:08 PM
rdauenhauer   :headbanger:   Jul 12 2012, 08:39 AM
Tom   Nice work Nate. What a cool shop car! Would p...   Jul 12 2012, 08:53 AM
aircooledtechguy   Would putting baffles in the tank help with weigh...   Jul 12 2012, 04:01 PM
OU8AVW   Awesome! Simply Awesome!   Jul 12 2012, 09:12 AM
aircooledtechguy   The Porsche fornication continues. . . :evilgrin:...   Aug 9 2012, 08:23 PM
aircooledtechguy   I finally got a chance to really put the "Squ...   Aug 31 2012, 12:22 AM
FourBlades   This is such a great thread. You've got some ...   Aug 31 2012, 06:19 AM
NORD   I'm glad you all got to see I let Nate by me. ...   Aug 31 2012, 04:26 PM
aircooledtechguy   Nate was lieing about the speeds we were going ...   Aug 31 2012, 09:11 PM
speed metal army   I love this thing! Buddy of mine is scooping a...   Aug 31 2012, 10:10 PM
aircooledtechguy   Question! Why the heck did you weld up the ta...   Aug 31 2012, 11:19 PM
speed metal army   Question! Why the heck did you weld up the t...   Aug 31 2012, 11:37 PM
aircooledtechguy   Here's the 2nd leg from the ski lodge down abo...   Sep 1 2012, 08:42 AM
aircooledtechguy   The relentless quest for more power and speed cont...   Sep 19 2012, 10:04 AM
Cap'n Krusty   Having had a bad experience with hydraulic hand br...   Sep 19 2012, 10:44 AM
aircooledtechguy   One thing that consistently bugs me about ALL A/C ...   Sep 27 2012, 09:05 AM
Vacca Rabite   ...Porsche 911 Nikasil-coated Aluminum cylinders....   Apr 3 2013, 12:22 PM
aircooledtechguy   I was thinking about this today. Wouldn't th...   Apr 3 2013, 03:18 PM
aircooledtechguy   I finally got the opportunity to make a mount for ...   Nov 26 2012, 01:47 PM
JRust   Nice! Love heated seats in the good old PNW. E...   Nov 26 2012, 02:41 PM
ChrisNPDrider   OMG I want cup holders like those! :beer2:   Nov 26 2012, 03:34 PM
aircooledtechguy   Big changes coming to the ProVolks shop car. . . ...   Mar 4 2013, 10:52 PM
aircooledtechguy   Friday, a friend of mine came by the shop to help ...   Mar 19 2013, 06:18 PM
Vacca Rabite   Badassed!   Mar 19 2013, 07:14 PM
Kirmizi   :popcorn:   Mar 19 2013, 09:26 PM
RickS   This is good stuff!   Mar 19 2013, 10:43 PM
audio_file   I'm such a sucker for (all) wagons, love it...   Mar 20 2013, 06:38 AM
rdauenhauer   Break out the Teener front end!   Mar 20 2013, 08:22 PM
aircooledtechguy   Break out the Teener front end! Patients Ri...   Mar 20 2013, 10:14 PM
aircooledtechguy   Am I missing something here????? :shock: The ...   Apr 3 2013, 11:55 AM
aircooledtechguy   Made a fair bit of progress today. Made the box-i...   Apr 4 2013, 07:24 PM
aircooledtechguy   I finally got the Porsche front mounts that I cut ...   Apr 9 2013, 10:46 AM
aircooledtechguy   Made a ton of progress this Saturday. Here are th...   Apr 29 2013, 09:03 AM
Dr Evil   Dibs if you ever sell this :)   Apr 29 2013, 04:06 PM
5 Pages V  1 2 3 > »
53 User(s) are reading this topic (53 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 27th November 2024 - 01:46 AM
