> first start of new motor, do I prime the oil pump?, should I have to prime it manually... whats wrong?
brant
post Dec 26 2011, 04:46 PM
any builders out there care to give me tips?
I rebuilt a 2.0 4 cylinder and tried to do a first start up on it for Christmas day.
Its in the garage... but very cold... probably had been around 10F the night before. The garage was warmed up with a kerosene heater, but I know the block was still pretty cold. Oil is brad Penn break in. Full rebuild... melling oil pump
So I know the oil is cold, but I've got it a touch over full and know the oil filter will hold a tiny bit more by the time oil fills it and all of the passages. Its not cold like molasses... its still flowing and the ambient in the garage is probably 55-60 at this point.
I pullled the coil wire and tried to turn the starter over to build pressure. After about 6 long cranks (approximately 8 seconds each?) I still don't have pressure on the gauge or the idiot light
So I pull the sender wire and verify the gauge is OK. Next I pull the sender off of the end of its flexible tubing and point the tube into a bucket while the car is cranked one more time.... No oil in the flexible tube.
Next I pull the oil filter and its got about 4/5ths (that I pre filled it with) but not wet and not full... no oil to the filter yet.
Next I put a piece of hose onto the threaded collar that the oil filter normally screws onto. I blow with my mouth and there is a tiny bit of resistance but definitely not plugged. I can hear air blowing into the sump.
finally I drain the oil and pull the tuna can... the pick up looks fine really from what I can tell through the sump hole.
So the motor has been cranked about 9 or 10 times total
I estimate that is about 90 seconds or a little less.
the last 2 or 3 times I cranked it It started to turn a little faster or "more freely" which I assume is the bearings and things fitting into each other.
I'm freaked about cranking it dry any longer.
its got a new raby cam and everything... I don't want to damage the lifters, etc.
I had used white lithium greas in the pump gears at assembly. Its a very viscous grease and shouldn't be "hard" from the temperature
Questions:
- Is there a way to prime the oil pump now? (maybe putting pressurized oil into the tubing on the oil filter collar, and having that run down hill into the pump gears?)
- am I just being a freak... and need to keep cranking it over longer or more due to the cool weather?
thanks in advance for any advice, especially "been there and know" kind of knowledge.
brant
Jake Raby
post Dec 27 2011, 02:03 PM
Engine Surgeon
Filling the oil filter means you are expecting AIR in the primary oil system to PUSH the oil out of the filter and through the engine. Allowing the system to fill and bleed naturally is the only thing that works. Loosening the filter as the Cap'n mentions is also very effective.
Air won't push oil very well at all..
brant
post Dec 27 2011, 02:10 PM
QUOTE(Jake Raby @ Dec 27 2011, 01:03 PM) *
I definitely screwed up on that one
how bad would the 8-9 attempts to crank be? (given that everything was well pre-
lubed at assembly)
do you prefill oil filters on routine oil changes?..... or always put filters on dry for even routine oil changes?
brant   first start of new motor, do I prime the oil pump?   Dec 26 2011, 04:46 PM
flash914   You could pull the sender and with a low pressure ...   Dec 26 2011, 05:12 PM
brant   You could pull the sender and with a low pressure...   Dec 26 2011, 05:17 PM
bam914   Pull the oil filter off and get oil to pump out. ...   Dec 26 2011, 06:10 PM
PancakePorsche   I rigged up a transmission funnel with a hose and ...   Dec 26 2011, 08:15 PM
76-914   Hey Brandt, just loosen the filter, crank until oi...   Dec 26 2011, 08:16 PM
jcd914   I think the oil in the filter makes it harder. The...   Dec 26 2011, 08:59 PM
Elliot Cannon   I think the oil in the filter makes it harder. Th...   Dec 26 2011, 10:02 PM
Ferg   Sounds like you need a beer, If you are still work...   Dec 26 2011, 09:51 PM
Dave_Darling   I used a turkey baster to squirt some oil up into ...   Dec 26 2011, 11:18 PM
Cap'n Krusty   And the winner is ................ Loosen the oil...   Dec 26 2011, 11:35 PM
vwsamba   :agree: and should'nt it be vaseline in the oi...   Dec 27 2011, 12:55 AM
aharder   Sounds like you need a beer, If you are still wor...   Dec 27 2011, 01:15 AM
brant   Wow... I did not know about the oil filter air poc...   Dec 27 2011, 09:16 AM
SLITS   Wow... I did not know about the oil filter air po...   Dec 27 2011, 11:59 AM
brant   Wow... I did not know about the oil filter air p...   Dec 27 2011, 12:03 PM
Jake Raby   Thats the reason why it would not prime. Pre- f...   Dec 27 2011, 01:19 PM
brant   Thats the reason why it would not prime. Pre- ...   Dec 27 2011, 01:25 PM
stugray   Brant, I have an oil cooler adapter with hoses th...   Dec 27 2011, 01:38 PM
brant   Thank you Stu I think I have one too I can use. bu...   Dec 27 2011, 01:59 PM
Jake Raby   Filling the oil filter means you are expecting AIR...   Dec 27 2011, 02:03 PM
brant   Filling the oil filter means you are expecting AI...   Dec 27 2011, 02:10 PM
stugray   Brant, I once fired up a newly rebuilt K Ghia eng...   Dec 27 2011, 02:22 PM
jmill   The only filter I've ever pre-filled was on my...   Dec 27 2011, 02:28 PM
stugray   So while on this topic: What is the consensus on w...   Dec 27 2011, 02:51 PM
McMark   Stu, every engine builder will give you their gosp...   Dec 27 2011, 03:35 PM
doug_b_928   Somewhat reluctantly (because it's oil-related...   Nov 5 2023, 10:09 AM
Geezer914   So if the oil filter is installed empty isn't ...   Nov 5 2023, 10:43 AM
technicalninja   I haven't had to try this on a T4 but on the v...   Nov 5 2023, 01:33 PM
- Lo-Fi Version Time is now: 15th January 2025 - 11:34 AM
