mrbubblehead |
Twodollardoug ![]() ![]() ![]() Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California ![]() |
i just wanted to start a thread to see what you guys do day to day on your cars.
i'll start, about a month ago, i pulled my engine and trans to put in a new clutch. had the flywheel lightened and resurfaced. but what i didnt know is that i had to shim the little ball that the clutch arm rides on, after a resurfacing. so guess what i did today? yup, pulled the trans and put an extra washer under the ball. you have to goop up both washers to get it to seal because the threaded hole goes all the way thru to the inside of the trans. i also replaced the plastic cup that the ball rides in. the throwout bearing and its little plastic blocks were fine so i buttoned every thing back up. 5 hours total. i think this has been the cheapest repair yet on my car. $2.75 for the little plastic cup. what did you do to your 914 today? |
914.SBC |
Member ![]() ![]() Group: Members Posts: 248 Joined: 12-December 10 From: CORONA, CA Member No.: 12,479 Region Association: None ![]() |
I had a slight exhaust leak so I used it as my excuse to buy some new ceramic coated and polished headers. Also installed billet fittings that mount on the block. I used plubming fittings because I cold not find billet fittings but learned that Mezzier sold them.
Car runs cool, fast and sounds much better with no exhuast leak due to the crappy headers I had on. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 30th June 2024 - 03:13 PM |
