mrbubblehead |
Twodollardoug ![]() ![]() ![]() Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California ![]() |
i just wanted to start a thread to see what you guys do day to day on your cars.
i'll start, about a month ago, i pulled my engine and trans to put in a new clutch. had the flywheel lightened and resurfaced. but what i didnt know is that i had to shim the little ball that the clutch arm rides on, after a resurfacing. so guess what i did today? yup, pulled the trans and put an extra washer under the ball. you have to goop up both washers to get it to seal because the threaded hole goes all the way thru to the inside of the trans. i also replaced the plastic cup that the ball rides in. the throwout bearing and its little plastic blocks were fine so i buttoned every thing back up. 5 hours total. i think this has been the cheapest repair yet on my car. $2.75 for the little plastic cup. what did you do to your 914 today? |
reharvey |
Senior Member ![]() ![]() ![]() Group: Members Posts: 573 Joined: 16-July 08 From: N. E. Ohio Member No.: 9,308 Region Association: North East States ![]() |
Finally got the trans back together and bolted to the engine. Going to install the engine next week. Ray (IMG:style_emoticons/default/beerchug.gif)
Attached thumbnail(s) ![]() |
RickS |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,408 Joined: 17-April 06 From: 'False City', WA Member No.: 5,880 Region Association: None ![]() |
Finally got the trans back together and bolted to the engine. Going to install the engine next week. Ray (IMG:style_emoticons/default/beerchug.gif) I thought I had something to share but after looking at that piece of art, I foreget... |
reharvey |
Finally got the trans back together and bolted to the engine. Going to install the engine next week. Ray (IMG:style_emoticons/default/beerchug.gif) I thought I had something to share but after looking at that piece of art, I foreget... Got the windshield trim installed without wrecking it or maring the paint. Thank God (IMG:style_emoticons/default/smilie_pokal.gif) Attached thumbnail(s) ![]() |
Lo-Fi Version | Time is now: 30th June 2024 - 03:41 PM |
