> Making " car trailer ", Reno or bust
Trekkor
post May 6 2004, 11:07 PM
I do things...
I'll be fabbing my work/utility trailer to accept my 914.
I'll widen the deck by a foot and make 9 foot loading ramps.
The sides all come off and it is a flat bed.
The yellow job box will be moved 3 feet foward to allow the car to come all the way foward. I'll add tire stops and tie downs.
I picked up the chassis for this trailer 3 years ago for $50.
It was orig a boat trailer. (low deck).
I put over 5000#'s on it all the time so I know our light wieght friend will be an easy rider.
I enjoy welding ( stick and wire ) and fab'n, so this weekend should be fun. (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/sawzall-smiley.gif)
URY914
post May 7 2004, 11:40 AM
You're right about needing a place on the car to tie down to.
I'd like to see someone come up with a piece that would go on the rear shock bolt so you could tie your hook strap to.
Make it out of a high grade steel plate maybe an 1/8" thick, with a small hole to go over the bolt and a large hole for the tie down hook.
Know what I mean? I'd buy two.
Paul
trekkor   Making " car trailer "   May 6 2004, 11:07 PM
Brad Roberts   That will work fine :trophy: Jason is "sprucing"...   May 6 2004, 11:31 PM
Mueller   finally we have a new member as sick as i am :) w...   May 6 2004, 11:35 PM
Brad Roberts   He wanted to lay tile at HPH for parts.. told him ...   May 6 2004, 11:37 PM
Rob Ways   Mmmm a welder in the 914 family..... this could be...   May 7 2004, 12:30 AM
Mueller
  May 7 2004, 12:43 AM
trekkor   hee haw :D   May 7 2004, 08:02 AM
groot   I built my trailer, too. My brother fired up the s...   May 7 2004, 08:10 AM
URY914   My trailer is aluminum, but you probably quessed t...   May 7 2004, 09:42 AM
Randal   Trekkor, Are you going to add the flush tie down ...   May 7 2004, 10:23 AM
URY914   You're right about needing a place on the car ...   May 7 2004, 11:40 AM
Randal   Paul, Rear shock bolt...now that sounds like a go...   May 7 2004, 12:18 PM
URY914   They need to be about 2"- 3" long. And not too th...   May 7 2004, 12:46 PM
seanery   hey guys, someone already makes those. pics around...   May 7 2004, 01:58 PM
Randal   What I found was these at PP:   May 7 2004, 04:21 PM
Randal   And this one:   May 7 2004, 04:21 PM
Randal   Both of these are $$$$ and I w...   May 7 2004, 04:23 PM
peridotian   If it is a flat peice from 1/8 steel, someone draw...   May 7 2004, 04:25 PM
Randal   Patrick, Let me know when they are done, so I can...   May 7 2004, 05:25 PM
Randal   Much nicer than my Home Depot Special (HDS)!   May 7 2004, 05:29 PM
trekkor   Going shopping right now and then the fun begins. ...   May 7 2004, 05:36 PM
Randal   Mr. T. I think those trailer guys down on SoCal h...   May 7 2004, 05:52 PM
trekkor   I'm looking for something that will also be pr...   May 7 2004, 06:01 PM
seanery   OK, this is wierd. The Performance Products part #...   May 7 2004, 06:34 PM
seanery   ok, they list it as a 911 part # Perf Products tow...   May 7 2004, 06:36 PM
d914   have some thing simular but much cheaper, engine l...   May 7 2004, 07:06 PM
Randal   I must say that the PP design is really nice. It ...   May 7 2004, 07:14 PM
Randal   Mr. T. If your looking for tie down straps Jegs u...   May 7 2004, 07:21 PM
trekkor   Hey ,Randal ! Thanks for the web link. My pr...   May 8 2004, 10:54 PM
Randal   Mr. T. Pat Costin will be designing the Reno cour...   May 8 2004, 11:00 PM
Randal   Mr. T. Now that is a serious BBQ. Does the grill...   May 8 2004, 11:01 PM
trekkor   The pic shows 13 whole tri-tips on the grill. The...   May 8 2004, 11:18 PM
trekkor   Later this month I will resume car trailer mods. ...   May 14 2004, 10:56 AM
trekkor   I'm resuming the trailer mod, now that I have ...   Feb 15 2005, 04:06 PM
mharrison   I hauled my new teener 450 miles this past weekend...   Feb 15 2005, 04:21 PM
!   More weight up front towards the tongue is a good ...   Feb 15 2005, 04:33 PM
trekkor   Kinda funny at the dump today. We unloaded the gar...   Feb 16 2005, 12:42 AM
trekkor   Made some progress tonight. All the new frame wor...   Feb 18 2005, 02:29 AM
Randal   Instead of 2X6's, wonder what thickness of alu...   Feb 18 2005, 09:59 AM
trekkor   http://www.914world.com/bbs2/...   Feb 18 2005, 11:26 PM
maf914   KT, Are the open areas on the inside of the fende...   Feb 19 2005, 07:43 AM
URY914   I added some sheetmetal to the inside of my fender...   Feb 19 2005, 08:45 AM
trekkor   Good idea on the fenders! I'll weld some ...   Feb 19 2005, 10:10 AM
trekkor   Towed the free car back to Napa today from San Jos...   Feb 20 2005, 09:00 PM
Aaron Cox   <...   Feb 20 2005, 09:01 PM
trekkor   Easy to load   Feb 20 2005, 09:03 PM
trekkor   Since I've had this trailer ( over four years ...   Feb 20 2005, 09:07 PM
neo914-6   http://www.914world.com/bbs2/ht...   Feb 20 2005, 09:09 PM
trekkor   #746 up and on http://www.914world....   Mar 3 2005, 02:38 PM
trekkor   other view KT   Mar 3 2005, 02:40 PM
Air_Cooled_Nut   Let's see the ramps, attached and stowed. May...   Mar 4 2005, 08:03 AM
URY914   I used a jobox on my trailer years ago. Great for ...   Mar 4 2005, 08:17 AM
URY914   I forgot: get a spare tire. You'll carry it fo...   Mar 4 2005, 08:20 AM
- Lo-Fi Version Time is now: 10th November 2024 - 12:18 PM
