Transaxle oil cooler pumps |
pcar916 |
Dec 29 2011, 07:27 AM
Is that a Lola? Group: Members Posts: 1,523 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None |
How many of you are using gear pumps instead of diaphragm types and what filter element (micron) sizes are you using?
john rogers |
Jan 4 2012, 05:23 PM
Senior Member Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
Well, for various HP ratings, Black Forest in San Diego and their race mechanic and at two other shops used this rule of thumb:
100 to 140 HP just keep the bushings and parts tight. 140 to 220 HP use a cooler and you could get 2 years of racing if you were careful. 220 to 300 HP use a cooler and rebuild at the end of the year for sure or sooner. Note a 915 can be used but over an average of 10 years of racing the total cost is nearly the same. 300 HP and up use a Turbo transmission especially if over 350 HP with a lube system. The 914 Bonneville car that had 850 HP used a Turbo 4 speed and cooler setup and never had transmission issues although it kept spinning out when the NO2 was cut in at 185 MPH or so! |
Lo-Fi Version | Time is now: 24th November 2024 - 12:38 AM |
