EdArango |
914 Enthusiast ![]() ![]() Group: Members Posts: 267 Joined: 30-January 10 From: Huntington Beach, CA Member No.: 11,309 Region Association: Southern California ![]() |
Hi Everyone,
So I would like to install some rear pickup point reinforcement ........ Is Tangerine Racing the only vendor that sells these???? http://www.tangerineracing.com/chassis.htm Is there someone else that produces this at a more reasonable price?? Please let me know ! Thanks Ed |
J P Stein |
Irrelevant old fart ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None ![]() |
Brant
I never had a lick of problems with the outer mounting point ear. Toe settings lasted a season as set.....checked alignment at the start of the season ...most years. If you use a Heim joint, the bolts need to be "fitted" within the joint itself and to the mounting holes on the chassis (that makes for a 0 slop joint). If not, one can take out the slop in by pre-loading but only in one direction of thrust, not both. Welding is a 0 slop joint, however, the area that one typically attaches the inner ear bar to is 16- 20 gauge sheet metal (Moggy did a better job there than most I've seen). A very large backing plate to prevent "oil canning" the area. I believe in overkill....one of my many character flaws. (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 25th June 2024 - 11:36 PM |
