Highland |
Senior Member ![]() ![]() ![]() Group: Members Posts: 513 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California ![]() |
I'm trying to disassemble my engine and can't get my oil pump out. I removed the 4 nuts and pulled so hard I broke off one of the ears.
Am I missing a fastener somewhere? Any advice would be appreciated. |
nathansnathan |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,052 Joined: 31-May 10 From: Laguna Beach, CA Member No.: 11,782 Region Association: None ![]() |
It may be necessary to loosen the case parting nuts that are near the pump. The stock pump is a tight fit in there.
Highland |
nathansnathan |
It may be necessary to loosen the case parting nuts that are near the pump. The stock pump is a tight fit in there. Thanks. That did the trick. Any recommendations on a replacement pump for the one I broke? That's a whole can o worms there. Used to be the type 1 shadek pumps were the solution, but the od of the body is(became?) too small. I think the melling pump maybe is the one to get now, though it is steel and some say that expansion rates differing will cause leaks. To do the type 1 pump though, you have to split the case and use a modified cam gear/ check for clearances, etc. Not sure about the Melling, if it's a similar situation. |
Lo-Fi Version | Time is now: 25th June 2024 - 01:05 AM |
