Stonepilot |
Newbie ![]() Group: Members Posts: 20 Joined: 6-December 11 From: Pensacola, Florida Member No.: 13,863 Region Association: South East States ![]() |
Anybody done one of these? Got a picture would love to see what it looks like? Thank you
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,641 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
cross post from my street car thread:
Attached thumbnail(s) ![]() Attached image(s) ![]() |
bulitt |
Achtzylinder ![]() ![]() ![]() ![]() Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States ![]() |
brant |
cross post from my street car thread: I'm thinking you could close off the front half of your opening and not lose much airflow? My front opening is smaller than the liscense plate I leave the plate on most of the time and only pull the plate when I need the cooling... (ie: heat of the summer, or track time) I've use the exact (and acutal) same cooler in three different exit configurations each one opened up and increased the exit size, and correspondingly dropped the oil temperature this one has a HUGE exit for a very small cooler and is 20degrees F cooler oil temps on the track than my most restrictive experiment (same cooler, same car, same motor, different day) I agree with the old rule of thumb about using 2x the exit size of your cooler entrance size.... (that hot air expands and a good exit draws more air through the cooler) |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,694 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
this one has a HUGE exit for a very small cooler and is 20degrees F cooler oil temps on the track than my most restrictive experiment (same cooler, same car, same motor, different day) One would think that with a louvered cover (even if only partially covering that huge hole) you could get pretty close to the same actual open surface but with a much better visual result. (IMG:style_emoticons/default/idea.gif) |
Lo-Fi Version | Time is now: 20th June 2024 - 09:12 AM |
