tired of leaking oil pump type IV, made a new oil pump cover plate |
914dave |
Jan 6 2012, 08:08 PM
914 Addict Group: Members Posts: 721 Joined: 19-October 03 From: Willow Grove Pa. Member No.: 1,262 Region Association: North East States |
It seems as thought every new oil pump I put on a type IV motor wants to leak. I've had to flat grind three previous cover plates to get them to stop leaking. We just finished the rebuild on a friends motor (" Dion "on World) and the @#*& thing is leaking. I think the plates are too thin and deform between the bolts and leak. The onion skin gasket isn't enough to make up for the .0015"-0030" warp in the plate. Which is the amount of bow I've found in all three cover plates. It's really meant to give the correct end play for the pump gears. So I decided to make a thicker plate with counterbored recesses for the nuts. It's been flat ground and shold be nice and dry, the rest of the motor is! We're rebuilding the gearbox this winter, so it won't be back in the car for a couple of months. Here's the pic of the new one vs. the stock one.
bobhasissues |
Jan 6 2012, 09:35 PM
seemingly endless issues with my 914 Group: Members Posts: 218 Joined: 13-February 07 From: Chicagoland Member No.: 7,532 Region Association: None |
That is a nice cover, I agree please make them available for sale.
I have had the same problem with my Melling cover. This spring, if I can't buy one of your covers, I am going to use a modified type 1 cover just like Jake used to supply when he was selling Shadek pumps. The outside edges are rolled up to prevent the cover from twist/warp. Proven problem solver for Jake. |
Lo-Fi Version | Time is now: 6th January 2025 - 07:05 PM |
