EdArango |
914 Enthusiast ![]() ![]() Group: Members Posts: 267 Joined: 30-January 10 From: Huntington Beach, CA Member No.: 11,309 Region Association: Southern California ![]() |
Hi Everyone,
So I would like to install some rear pickup point reinforcement ........ Is Tangerine Racing the only vendor that sells these???? http://www.tangerineracing.com/chassis.htm Is there someone else that produces this at a more reasonable price?? Please let me know ! Thanks Ed |
ChrisFoley |
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,937 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None ![]() ![]() |
Removable rods are absolutely required for a -4 with full tin or for a -6.
The left and right threaded rod ends make installation/removal simple. Non-threaded removable rods could be used but precise installation/welding would be critical. I use fairly inexpensive (non teflon) 3/8" rod ends in my kit but they're sufficiently strong and tight for the application, which is static (ie. no motion). Only 10% of the value of the complete kit is in the rod ends. 7/16" is overkill IMO, the bending loads are real small and 3/8" is fine in tension/compression. The mounting brackets for the heim braces, made in-house, are more costly than they may appear - they require specialized tooling and precise fabrication. I include long bolts to attach the rod ends because shorter bolts would have the threads inside the hole, allowing movement in the assembly. The tubes are 1" od x .065w Chrome-Moly (primed only), which is plenty stiff without adding much weight. We weld the threaded bushings in-house. All the sheetmetal is CNC plama-cut and formed, in-house. I think I've done about everything I can to control costs without cheating on the value of the final product. |
Lo-Fi Version | Time is now: 25th June 2024 - 11:39 PM |
