jmargush |
Member ![]() ![]() Group: Members Posts: 463 Joined: 8-June 04 From: Goshen, IN Member No.: 2,176 ![]() |
Is there a trick to getting the clutch retaining bolts out? they sit right against the ring gear on the flywheel preventing a socket from sliding on. and I can seem to get a good grip with an open end.
A&PGirl |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,019 Joined: 4-January 06 From: Oklahoma Member No.: 5,367 Region Association: None ![]() |
The 1.7/1.8 Clutches use a shorter length bolt than the 2.0.
The -6 Clutches use the same length bolt as the 1.7/1.8. They all should have washers underneath the head. The -6 and -4's list the same p/n for the clutch & pressure plate. |
Lo-Fi Version | Time is now: 25th June 2024 - 08:41 PM |
