914-6 Steering column bearing upgrades?, Failed bearing in steering column and associated parts? |
david63 |
Jan 9 2012, 05:04 PM
Member Group: Members Posts: 96 Joined: 9-August 09 From: Parker Colorado Member No.: 10,653 Region Association: Rocky Mountains |
When I took the steering wheel off the car the other day (was going to install a Momo Prototipo wheel) the steering shaft bearing assembly has apparently failed (ball bearings "loose" and several missing). When this part is new is it all contained (meaning the small ball bearings are not "loose"? Next question "is there any sort of upgrade that eliminates this part and replaces it with a poly bushing similar to the replacement part on the newer 911 steering column"? The attached picture shows the failed part as #6 (I know 914-6 parts are expensive but WOW this bearing is +/- $250.00). Thanks, |
laflaur |
Jan 9 2012, 05:36 PM
Member Group: Members Posts: 162 Joined: 8-June 06 From: Granite Bay Member No.: 6,186 Region Association: Northern California |
Hey David,
There is a guy on the bird board that makes a replacement insert for the column. Let me do a search... |
Lo-Fi Version | Time is now: 26th June 2024 - 04:58 AM |
