aharder |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,433 Joined: 6-September 11 From: Dallas Texas Member No.: 13,524 Region Association: Southwest Region ![]() ![]() |
I'm installing new rings in my 1.8 and I've been told two different processes so
I wanted to get your input as to which one is best I was told that you can pull the cylinders and leave the pistons on the rod and replace the ring and then install the cylinder back on the piston while it is still connected to the rod. I was also told that you can remove the piston from the rod and replace the rings and put the piston back in the cylinder while not connected to the rod and then connect back to the rod. What do you think (IMG:style_emoticons/default/confused24.gif) |
JFJ914 |
Senior Member ![]() ![]() ![]() Group: Benefactors Posts: 813 Joined: 13-June 03 From: Alpharetta, GA Member No.: 814 Region Association: South East States ![]() ![]() ![]() |
Are you going to get the ridge at the top of the cyl removed so you don't break the top ring when you start it? The cyl's also require honing and that requires the cyl to be clamped in a fixture duplicating the block/head so the cyl will stay round.
Lo-Fi Version | Time is now: 1st July 2024 - 06:17 AM |
