> 76/2.0/4 hard start
street legal go-kart
post Apr 15 2003, 09:16 PM
Miss Mari's slave
gdday
ONE car has always started with no throttle or any extended cranking . even at 20 degrees f . ALWAYS started and idled at 900 rpm at once .
sat morn. had to blip th throttle to keep the car running and restart the car numerous times . if i held the engine at at a steady rpm the engine would drop and die within 2 secs . checked for any loose conectors etc.
mon same thing
after i let the car sit all day , not as dramatic the but the same thing .
after about 2 mins , the car behaves as always , (IMG:style_emoticons/default/confused24.gif)
same level of perfomance .
no fuel line leaks , new points in the fuel pump , fuel filter 500 miles ago etc .
any help thx in advance
jt
post Apr 16 2003, 08:45 PM
Miss Mari's slave
thanks for the ideas
on my way out to try both ideas. (IMG:style_emoticons/default/sad.gif)
i mean the car didnt even hickup on cold starts
procedeure was to cycle the fuel pump for 2 secs and light it . 900 rmps steady not a burp or anything. drive it away at reduced rpm etc as per factory instruction.
thx again
results to follow
jt
- Lo-Fi Version Time is now: 14th January 2025 - 07:13 AM
