Corner Balancing Question, With a twist |
ellisor3 |
Jan 16 2012, 04:32 PM
HPWhore Group: Members Posts: 811 Joined: 23-October 08 From: Fleming Island, Florida Member No.: 9,683 Region Association: South East States |
I took my car to get it corner balanced, and all seem to work out pretty well. Then went to get the alignment and had some issues. I posted about that and got some really good feedback that will help me solve the problem.
Then today as I was looking at the situation again I noticed another problem. The ride height of my car is higher in the passengers rear than the drivers rear by 2.5 cm. I don't know how I or the shop that did the corner balancing missed it. Here are the numbers from the weighing LF 599 RF 541 =1140 LR 724 RR 678 =1402 Total weight 2542 Left side is 52% Right Side is 48% Cross weight is 50.23 To Correct the balancing, take the weight of the total of the front and multiply by the corner to be corrected: 1140x52%=593 for the LF 1140x48%=547 for the RF 1402x52%=729 for the LR and 1402x 48%=673 for the RR Corrected quadrants LF 592(-7) RF 547 (+7) LR 729 (+5) RR 673 (-5) Since I have steel flares, I measured the height from the floor to the lip of the flares and they are the same. I also checked the height setting on the shocks (Bilstein Sports) and they are equal to each other. What would make the car higher on one side? Could the sway bars cause this? It seems one option would be to raise the LR to not only equal the weight but correct the ride height. The only thing that puzzles me about that is that the shocks would be set in two different positions, is that normal?? |
TravisNeff |
Jan 16 2012, 05:14 PM
914 Guru Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region |
It would be more accurate to measure from the ground to the donuts, rather than the fender lip opening.
brant |
Jan 16 2012, 05:37 PM
914 Wizard Group: Members Posts: 11,739 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
It would be more accurate to measure from the ground to the donuts, rather than the fender lip opening. especially on a car that has had flares added. the car could of been sitting wrong (anything... corner balance, low tire, sway bars) at the time the flares were installed meaning your fender appearance was set on wrong the donuts are prettty good. I use the front adjustment bolts on the front measurement |
SirAndy |
Jan 16 2012, 05:55 PM
Resident German Group: Admin Posts: 41,815 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
It would be more accurate to measure from the ground to the donuts, rather than the fender lip opening. especially on a car that has had flares added. the car could of been sitting wrong (anything... corner balance, low tire, sway bars) at the time the flares were installed meaning your fender appearance was set on wrong the donuts are prettty good. I use the front adjustment bolts on the front measurement (IMG:style_emoticons/default/agree.gif) |
Lo-Fi Version | Time is now: 25th September 2024 - 11:01 PM |
