What size rear springs for an LS1?, worried that the 100 lb-ers may be too soft. |
dadaDaveed |
Jan 17 2012, 05:05 PM
Member Group: Members Posts: 111 Joined: 19-February 09 From: San Antonio, TX Member No.: 10,071 Region Association: Southwest Region |
Before I decided to convert to an LS1, I was planning to use:
stock 914 torsion bars 100 lb. rear springs stock sway bars Bilsteins all around. The car is steel flared and will have a proper 5-bolt conversion running 16x8 up front and either 16x8 or 16x9 in the back. This will be a street-only car. Should I put stiffer springs in the back? If so, how much stiffer? |
jmmotorsports |
Jan 18 2012, 12:41 PM
Member Group: Members Posts: 308 Joined: 15-August 06 From: Kelso,Wa. Member No.: 6,658 Region Association: Pacific Northwest |
When I first built my car with the SBC I ran 21 mm torsion bars. 22 mm sway bar and 200 lb springs. When I put the LS1 in,I changed the rear to 180,front back to stock torsion bars. Still have the 22 mm sway in front with a stock bar in back.
This setup works for me for street and the 2 or 3 autox I do a year. Jerry |
Lo-Fi Version | Time is now: 25th June 2024 - 08:16 PM |
