Bullet |
Member ![]() ![]() Group: Members Posts: 116 Joined: 16-April 04 From: Newberg, OR Member No.: 1,940 ![]() |
I got the engine started tonight. And as it was running it was missing bad as if though it was running on only 3 Cylinders. But as i take the RPM to around 3k it starts to run really smooth. I cant help but to think that i might have a Fualty injector that is having a hard time opening up untill there is some good pressure behind it. I havent had the chance to Check for spark at all the cylinders or do a spray check on the injectors. Im just trying to get a plan on were to start first.
Also the right bank has a exhust leak that is comming from the head to headers I can look up and see where it left a dark spot on the Copper caskets. Have any of you guys tried exhuast sealent (it is a copper color) to try and fix this. and yes i checked the torque on the studs. |
Bullet |
Yeah the Throtle it self returns great. when i get in the car and push the pedal down it moves everything to wide open the way it is supposed to but just does not return unless i get down there an Pull the pedal back. I lean towards the pedal sticking becuse the car has not been driving (or assembeld for that matter) since 1989.
Lo-Fi Version | Time is now: 27th June 2024 - 07:41 PM |
