aircooledtechguy |
The Aircooledtech Guy ![]() ![]() ![]() Group: Members Posts: 1,966 Joined: 8-November 08 From: Anacortes, WA Member No.: 9,730 Region Association: Pacific Northwest ![]() |
I've had a long term project going now to turn my '67 Squareback into my shop car. While I love driving my 914, it has limitations as a daily parts hauler. I love old styling with new technology and updates, so my goal is to turn my humble Square into the wagon that Porsche never made. I want it to drive and handle more like a Porsche than a VW wagon and it's got to be a true "Sleeper" (not a real problem; since it's a wagon). (IMG:style_emoticons/default/shades.gif)
(IMG:http://www.914world.com/bbs2/uploads_offsite/images.thesamba.com-9730-1324689630.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/images.thesamba.com-9730-1324689631.2.jpg) This has been a 4-5 phase project. Phase-1 - Convert it to Porsche 914 2.0L motor. Make it physically adapted to the car and running MS2 w/ Ford EDIS ignition. Get it tuned to be a daily driver. DONE!! (IMG:http://www.914world.com/bbs2/uploads_offsite/images.thesamba.com-9730-1324689631.3.jpg) Phase-2 - Make the motor look good and freshen it up with new P&Cs. The heads were freshened only about 2K miles before I got it, by me when it was in a clients 914 that he converted to Subie power. I noticed that once I had a few miles on it myself, it was using a bit of oil. So I upgraded to a new set of 96mm P&Cs. So now it's a 2056. ![]() ![]() I had my local powder coater do all the tins in black and the plenum and runners in grey for a stock look. I'm running T-4 H/Es with a modified bus header and a Summit Racing Flow Master clone muffler. So I had those ceramic coated in black so they are not attention grabbers from the back. This car is a sleeper (IMG:style_emoticons/default/happy11.gif) ![]() DONE!! Phase-3 - Convert the rear suspension to the later style IRS and install a Porsche 923 trans out of a Porsche 912E. The rear suspension is DONE!! While at it, I upgraded it with 914 rear brakes, urethane bushings, adjustable spring plates and a rear sway bar. (IMG:style_emoticons/default/driving.gif) (IMG:http://www.914world.com/bbs2/uploads_offsite/images.thesamba.com-9730-1324689632.4.jpg) Since the trans is taller than a stock 4-speed and cutting into the car can't happen due to rear seat issues. I gained the 1.5" I needed by spacing the body off the rear suspension with spacers. So here I sit, on the final leg of phase-3. I now need to couple the motor/trans and lift it into it's final place and fab rear engine hanger mounts for the rear bar. It's late and I'm tired. . . Phase-4 - Front suspension upgrade. Currently in-work Phase-5 - Paint so it doesn't look so crappy, though it does add to the "sleeper" persona. . . Stay tuned for more later. . . |
aircooledtechguy |
Awaiting parts on a bunch of stuff, due to all the snow we have around here, so I figured I would make the most of my time.
I decided the dash would be my focus. I'm replacing the stock 3 gauges in favor of a pair of Porsche gauges (since they fit so nicely :wink: ) and a VDO tach that I had laying around. Before: (IMG:http://www.914world.com/bbs2/uploads_offsite/images.thesamba.com-9730-1327012533.1.jpg) pulled the gauges out and drilled holes in the dash for the new idiot lights since the Porsche gauges I'm installing do not have these. I had to install one for the alternator, oil pressure, high beam and blinker. They turned out pretty good so I don't mind making the cuts. (IMG:http://www.914world.com/bbs2/uploads_offsite/images.thesamba.com-9730-1327012534.2.jpg) Next I made a custom harness for the gauges so that I could simply plug into the Porsche gauges from the stock harness. I haven't tested the wiring yet, but how hard can a few idiot lights ans senders be, right?? (IMG:style_emoticons/default/laugh.gif) Famous last words. . . I still have wires to run back for the oil temp and speedo pick-up on the trans. I'm planning to run them along with the other gauge wiring when I run the CHT, oil pressure and volt meter. Finished: (IMG:http://www.914world.com/bbs2/uploads_offsite/images.thesamba.com-9730-1327012535.3.jpg) I am probably going to clock the tach so that the entire sweep is within view when the car is driving again. The Porsche 930 wheel is smaller and blocks the view from about the 1-4 o'clock positions. I also took some shots of the heater with the trans installed. Room-O-Plenty!! I'm going to spend the rest of the day making the adapters for the inlet hoses for the heater to car connections. I really like how the 69 Square with the BA4 had the fan mounted on the air duct. I may have to duplicate that!! (IMG:http://www.914world.com/bbs2/uploads_offsite/images.thesamba.com-9730-1327012535.4.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/images.thesamba.com-9730-1327012536.5.jpg) |
Lo-Fi Version | Time is now: 28th June 2024 - 11:38 PM |
