Transaxle oil cooler pumps |
pcar916 |
Dec 29 2011, 07:27 AM
Is that a Lola? Group: Members Posts: 1,523 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None |
How many of you are using gear pumps instead of diaphragm types and what filter element (micron) sizes are you using?
pcar916 |
Jan 14 2012, 11:04 AM
I thought I'd follow up with a summary of the approximate cooling system costs. This assumes you don't have any of this stuff lying about and that , instead of a diaphragm pump, you choose a mid-range gear pump with a catch can etc.
Pricing for hose fittings from Racer Wholesale Parts: 1. Cooler $ 90 2. Fan $ 70 3. Pump $275 4. Filter $ 75 5. Chk valve (1.2lb) $ 40 6. Fittings (-8AN) $308 (mandrel-bent except the vent system) 7. Hose (-8) $ 70 8. Catch can $ 70 (unless you make your own... I did) 9. Controller $ 30 Roughed out it'll be: $ 1,028 Someone out there is going to do this. For some reason I just can't get any new system into Penelope without spending $1,000. (IMG:style_emoticons/default/beerchug.gif) |
stewteral |
Jan 20 2012, 11:47 PM
Old Member Group: Members Posts: 384 Joined: 4-December 07 From: Camarillo, CA Member No.: 8,424 Region Association: Southern California |
I thought I'd follow up with a summary of the approximate cooling system costs. This assumes you don't have any of this stuff lying about and that , instead of a diaphragm pump, you choose a mid-range gear pump with a catch can etc. Pricing for hose fittings from Racer Wholesale Parts: 1. Cooler $ 90 2. Fan $ 70 3. Pump $275 4. Filter $ 75 5. Chk valve (1.2lb) $ 40 6. Fittings (-8AN) $308 (mandrel-bent except the vent system) 7. Hose (-8) $ 70 8. Catch can $ 70 (unless you make your own... I did) 9. Controller $ 30 Roughed out it'll be: $ 1,028 Someone out there is going to do this. For some reason I just can't get any new system into Penelope without spending $1,000. (IMG:style_emoticons/default/beerchug.gif) Hey Pcar916, I see that you have been working over the whole issue of trans cooling very diligently, but am left with ONE basic question: do you have empirical DATA so you KNOW your trans oil temp will run TOO HOT and that you MUST have an oil cooling system? You could find, as I did, that all that extra hardware is just NOT necessary. Best, Terry |
Lo-Fi Version | Time is now: 24th November 2024 - 12:22 AM |
