> Crank Position Sensor, for stock cooling engines
McMark
post Jul 13 2009, 10:11 AM
914 Freak!
Since quite a few people were interested in crank fire and aftermarket FI system I finally finished up my crank position sensor setup. So if you want to run distributor-less ignition or modern FI, this setup is the ONLY setup built specifically to bolt onto a Type 4.
It's a complete bolt on upgrade, which means no drilling or modifying any parts to make this work. Only the cooling fan needs to be removed to complete the installation.
This setup is great for modern FI system, which need a 'trigger signal'. Fuel only setups usually get their signal from the coil firing, but that signal is DIRTY and unreliable. This crank fire setup is smooth and clean. You can't beat it.
There is no other setup built specifically for our motors. Quick easy installation with no headaches.
Complete package price is $175 and includes the trigger wheel, the sensor w/ connector (pigtail or uncrimped), and the mounting bracket. You won't need to go searching for anything else.
(IMG:http://www.914world.com/bbs2/uploads/post-419-1244942673.jpg)
(IMG:http://www.914world.com/bbs2/uploads/post-419-1245008370.jpg)
McMark
post Jan 23 2012, 02:23 PM
914 Freak!
Flash, I haven't had time to set up my web-store. I have one more coil mount setup in stock and one more trigger wheel setup in stock. But I'm always making more, so they will be available in the future.
McMark   Crank Position Sensor   Jul 13 2009, 10:11 AM
rdauenhauer   I want one of these! What about a harness/con...   Jul 13 2009, 01:13 PM
McMark   I want one of these! What about a harness/co...   Jul 17 2009, 10:56 AM
JazonJJordan   :trophy: Excellent work- McMark! I will get o...   Jul 15 2009, 10:04 AM
euro911   :beer2: Very nice, but a question comes to mind: ...   Jul 16 2009, 12:05 AM
McMark   How do you deal with the added thickness? ... will...   Jul 17 2009, 10:58 AM
hcdmueller   The trigger wheel is machined to be the correct th...   Jul 16 2009, 08:01 AM
euro911   So the sensor replaces the trigger points in the d...   Jul 21 2009, 11:50 PM
McMark   This sensor is a key component of installing after...   Jul 24 2009, 02:15 PM
JazonJJordan   This sensor is a key component of installing afte...   Jul 24 2009, 09:34 PM
euro911   This sensor is a key component of installing afte...   Jul 25 2009, 04:16 AM
McMark   I'm trying to motivate my genius EE into devel...   Jul 24 2009, 09:39 PM
rdauenhauer   Does the placement of the Pickup preclude the use ...   Sep 19 2009, 01:30 AM
McMark   I think it might interfere with the return line. ...   Sep 19 2009, 01:36 AM
rdauenhauer   Perhaps if it was moved to the case pinch bolt jus...   Sep 26 2009, 12:02 AM
LotusJoe   Is your trigger system still avail.? Thanks Joe S...   Dec 8 2009, 04:51 PM
McMark   Yes it is.   Dec 8 2009, 05:19 PM
ConeDodger   Since this WOULD be the perfect solution for me, i...   Dec 16 2009, 11:17 AM
McMark   Looks like SDS is 'working on' toothed whe...   Dec 16 2009, 09:15 PM
arvcube   dont their systems currently work on magnetic trig...   Dec 16 2009, 11:09 PM
Mark Henry   dont their systems currently work on magnetic tri...   Feb 5 2010, 11:22 AM
McMark   Yup, SDS uses a hall effect sensor, which relies o...   Dec 16 2009, 11:34 PM
draganc   Yup, SDS uses a hall effect sensor, which relies ...   Jan 21 2010, 09:07 PM
McMark   My system only works with MegaSquirt for sure. It...   Jan 22 2010, 12:43 AM
underthetire   My system only works with MegaSquirt for sure. I...   Jan 22 2010, 10:17 AM
draganc   Thanks McMark, Do you offer a complet kit (HW, Me...   Jan 22 2010, 06:54 PM
McMark   My system only works with MegaSquirt for sure. ...   Jan 27 2010, 02:55 PM
McMark   I have a complete fuel injection system that is al...   Jan 27 2010, 02:53 PM
underthetire   Check here http://www.whiteproducts.com/metri-pac...   Jan 27 2010, 03:49 PM
jd74914   You can get Delphi WeatherPak connectors from Wayt...   Jan 28 2010, 04:35 PM
McMark   This connector is not any of the (seems like hundr...   Jan 28 2010, 04:40 PM
typ4   This connector is not any of the (seems like hund...   Jan 28 2010, 11:05 PM
arvcube   x2 on the question about what the sensor is off of...   Jan 29 2010, 01:00 AM
typ4   x2 on the question about what the sensor is off o...   Jan 29 2010, 11:14 AM
arvcube   x2 on the question about what the sensor is off ...   Jan 29 2010, 02:40 PM
jimkelly   for megasquirt II per - http://www.megamanual.com/...   Feb 6 2010, 01:46 PM
McMark   The adjustment in MegaTune is super easy and I can...   Jan 30 2010, 12:30 AM
McMark   Rich, I've looked at relocating the sensor for...   Feb 2 2010, 11:03 PM
jimkelly   for ignition only (using carbs) - what is needed? ...   Feb 5 2010, 06:58 AM
McMark   Which means my sensor works great for this. Rely...   Feb 5 2010, 02:33 PM
arvcube   i may be needing one of these pretty soon. are the...   Oct 28 2010, 11:20 PM
McMark   They are still available. I'm having more whe...   Nov 10 2010, 01:54 PM
arvcube   They are still available. I'm having more wh...   Nov 10 2010, 04:16 PM
rdauenhauer   Mark any more work on that full-flow config?   Nov 11 2010, 12:48 AM
McMark   Rob needs one now too, and his motor is here at th...   Nov 11 2010, 05:25 PM
tracer   McMark, take a look at these suppliers. Might help...   Dec 3 2010, 02:42 PM
McMark   Thanks for the tip. That's gonna take me whil...   Dec 3 2010, 02:48 PM
arvcube   Thanks for the tip. That's gonna take me whi...   Dec 3 2010, 03:12 PM
rdauenhauer   Rob needs one now too, and his motor is here at t...   Dec 17 2010, 03:04 AM
ConeDodger   Rob needs one now too, and his motor is here at ...   Dec 17 2010, 06:15 PM
rdauenhauer   My plans are to utilize it w/ a Ford /4 EDIS setup...   Dec 18 2010, 01:33 PM
McMark   My plans are to utilize it w/ a Ford /4 EDIS setu...   May 26 2011, 10:42 AM
draganc   "... The plate mounts securely to the oil co...   Jun 18 2011, 07:02 PM
McMark   I finally found connectors for this. So these are...   Mar 14 2011, 05:50 PM
Mike914   Mine came today, had a few minutes free so put it ...   Apr 1 2011, 01:25 AM
1973_1.7   Great product, I have been looking for at trigger ...   May 20 2011, 02:59 AM
McMark   I happen to have a DTM equipped engine in the shop...   May 20 2011, 02:02 PM
914Mike   I happen to have a DTM equipped engine in the sho...   May 23 2011, 12:54 AM
McMark   Okay, finally had a few minutes to try all this ou...   May 26 2011, 10:32 AM
914Mike   ... I'll make a final check this afternoon a...   May 28 2011, 05:12 PM
McMark   Sensor is a tight fit. I expect it will work fine...   May 31 2011, 06:41 PM
Krank   Sensor is a tight fit. I expect it will work fin...   Jun 20 2011, 12:07 AM
McMark   I found the connector and now include them in the ...   Jun 20 2011, 01:04 AM
1973_1.7   Do you sell just the trigger wheel? Price?   Jun 23 2011, 03:36 PM
John Jentz   Mark, are these CPS's still avaliable? Are yo...   Nov 23 2011, 12:30 PM
McMark   Yeah, they are still available. I'll shoot a ...   Nov 23 2011, 12:35 PM
John Jentz   Yeah, they are still available. I'll shoot a...   Nov 25 2011, 02:58 PM
flash914   <_< I can't find any info on the coil mo...   Jan 23 2012, 12:46 PM
McMark   Flash, I haven't had time to set up my web-sto...   Jan 23 2012, 02:23 PM
draganc   Flash, I haven't had time to set up my web-st...   Jan 25 2012, 09:56 AM
McMark   Dragan, I will get you a price. No word from Flash...   Jan 27 2012, 12:32 AM
flash914   Go ahead and let Dragan have it. Money set back, i...   Jan 29 2012, 08:43 PM
draganc   Go ahead and let Dragan have it. Money set back, ...   Jan 30 2012, 09:50 PM
1973_1.7   You still have these kits? i would like to order o...   Jul 18 2012, 01:24 AM
McMark   Yup, they're still available. But you should ...   Sep 5 2012, 11:32 AM
damo99   how much to ship one to australia thanks   Oct 1 2012, 04:07 AM
flash914   Mark, new year new money. I need prices from you o...   Jan 4 2013, 11:44 AM
Jesco Reient   Are these still available? I'm definitely look...   Jan 28 2014, 09:21 AM
- Lo-Fi Version Time is now: 20th April 2025 - 12:15 AM
