david63 |
Member ![]() ![]() Group: Members Posts: 96 Joined: 9-August 09 From: Parker Colorado Member No.: 10,653 Region Association: Rocky Mountains ![]() |
![]() When I took the steering wheel off the car the other day (was going to install a Momo Prototipo wheel) the steering shaft bearing assembly has apparently failed (ball bearings "loose" and several missing). When this part is new is it all contained (meaning the small ball bearings are not "loose"? Next question "is there any sort of upgrade that eliminates this part and replaces it with a poly bushing similar to the replacement part on the newer 911 steering column"? The attached picture shows the failed part as #6 (I know 914-6 parts are expensive but WOW this bearing is +/- $250.00). Thanks, |
1TRICK6 |
Newbie ![]() Group: Members Posts: 45 Joined: 13-July 11 From: Southern California Member No.: 13,313 Region Association: Southern California ![]() |
YO
phatnine11 |
Member ![]() ![]() Group: Members Posts: 286 Joined: 22-March 05 From: Rancho Cucamonga, CA Member No.: 3,798 ![]() |
Here's a pic of that bearing new. I had up/down slop in my steering wheel and thought it was the bearing but it turned out all I needed was a plastic bushing I ordered from Pelican. The plastic bushing is not even listed in the 914-6 parts manual. Not sure if you can just use the plastic bushing in lieu of the metal bearing, I got both of them in there now, along with the spring. Jimmy, Cesar here. We took auto shop one summer at Alhambra High. How are you, long time no talk. PM when you get a chance dude. Good to see you still have the Orange killer machine! Phatnine11 |
Lo-Fi Version | Time is now: 26th June 2024 - 05:18 AM |
