FS: $9.14 & more, * items added * |
914werke |
Oct 2 2008, 03:48 PM
"I got blisters on me fingers" Group: Members Posts: 10,190 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
For sale misc. items. (Pics start in 2nd post & may or may not be actual)
If you don’t see some thing you’re after, ask there's a good chance I have it. If you want something and feel the need to dicker, make offer. Trades welcome. I’m liquidating most all the stuff horded for my restoration, but left over, so I have a lot of bits and pieces. All parts are for /4 unless otherwise noted. All prices quoted less actual shipping/handling. (International sales via Fedex 100% shipping & item prepay only!) Because the majority of these items are for small $’s, Check, MO or buyer covers the fees Shipping can be combined on multiple items but in doing so *please* be patient, it can take some time to adequately pack the selection to avoid damage. Check back often, as things get snapped up Ill add more! |
rgolia |
Jan 24 2012, 10:17 AM
GeoJoe Group: Members Posts: 705 Joined: 5-February 10 From: PA Member No.: 11,329 Region Association: North East States |
For sale misc. items. (Pics start in 2nd post & may or may not be actual) If you don’t see some thing you’re after, ask there's a good chance I have it. If you want something and feel the need to dicker, make offer. Trades welcome. I’m liquidating all the stuff horded for my restoration, but left over, so I have a lot of bits and pieces. All parts are for /4 unless otherwise noted. All prices quoted less actual shipping/handling. (International sales via Fedex 100% shipping & item prepay only!) Because the majority of these items are for small $’s, Check, MO or buyer covers the PayPal fees (better yet check into POPMoney (IMG:style_emoticons/default/smile.gif) ). Shipping can be combined on multiple items but in doing so *please* be patient, it can take some time to adequately pack the selection to avoid damage. Check back often, as things get snapped up Ill add more! #3 Wiper motor & linkage assembly $65.00 #4 #6 Center plastic deposit tray $9.14 #7 Fresh air blower motor $50.00 #8 Fresh air blower box $30.00 #9 Fresh air controls (late) $45.00 #12 Gauge Bezel (metal) $15.00 #13 Headlight surround (white early) single $9.14 #14 Headlight surround (black late) each $9.14 #15 Late window regulators R or L $30.00 #16 OE late tie rods (screw vs pinch) pair 15.00 #17 R. Trunk spring bars (pair) $9.14 #18 Steering Rack (w/o shaft) $35.00 #19 Gravel shields (each) $25.00 #20 Headlight covers (pair) $9.14 #21 Headlight Eyebrows (pair) $9.14 #22 #23 #24 Targa Top storage Brackets (forward) per $9.14 #25 OE shifter (early or late) $30.00 #26 Gauge Cluster complete (early 120MPH, late 150MPH) $80.00 #28 Fuel/Combo guages (early & late) $20.00 #29 Front hood (PU only) $75.00 #30 Shift boot (rubber) $9.14 #31 F. turn signal lenses (pair, used cond.) $9.14 #32 F. turn signal buckets (per) $15.00 #33 A. pillar trim (per side) $15.00 #34 B. Pillar trim (per side) $9.14 #35 Front brakes (each) $15.00 #36 Rear Brakes (Pair) $45.00 #37 Headlight relay cover (black) pair $9.14 #38 Eng. Lid Grill (per) $20.00 #39 Exhaust tip w/bung $25.00 #40 Speaker pods each $20.00 #41 Retractable (late) seat belt set $45.00 #42 Seat belt latch whip (late) per $9.14 #43 Seat belt latch whip (early) per $9.14 #44 Front hood latch set $20.00 #45 Rear Deck latch set $20.00 #46 Horn set (late, pair) $25.00 #47 Black 1.7 script $9.14 #48 Round relays (black) each $4.00 #50 Chrome headlight trim rings (pair) $9.14 #51 OE Blk headlight trim rings (pair) $15.00 #55 Steering column 75-76 /4 $50.00 #58 Side marker assemblies w/Lens (per side) $30.00 #59 Headlight Bucket assemblies (restored complete pair) $125.00 #60 Rear US lens (average shape. per.) $50.00 #61 Late /4 Boge strut housings (each) $9.14 #62 Trans Ground strap $9.14 #63 Bumper Dog bones (pair) $9.14 #66 Glove box door /4 (early or late vinyl) $20.00 #67 Cam Gear $15.00 #68 Screw in Studs w/nuts (per)$1.00 #69 Transmission or early eng. mounts (NO cracks) Per. $15.00 #70 OE Valve covers Per. $10.00 #71 Alloy wheel lug bolts (Per.) $5.00 #72 Trunk Steel knockouts per $9.14 #73 Headlight bucket support steel per $9.14 #75 Black Plastic Door thresholds (late, pair) $20.00 #78 Leather Wheel Wrap $9.14 #79 Transmission Mount assemblies (complete pair) $40.00 #80 Complete wire loom (uncut) 72MY $75.00 #82 Brake fluid reservoir assembly (w/lines) $35.00 #83 Cabin Fresh air vents (per) $9.14 #84 Fuel Tank assembly (early or late) $100.00 #87 Rain tray (late) $30.00 #88 Carb Fuel Pump (Faucet style)$20.00[/s] #89 Holly fuel regulator (carb) $20.00 #91 OE Shift knob $35.00 #92 Steering rack bellows $9.14 #95 Lower dash pad(s) w/vents $25.00 #96 Lower dash pad (early no vents) $30.00 #97 Engine mount bar (Late sideshift) $30.00 #100 Heater fan outlet (single) $9.14 #106 Rain Tray Drain Tubes (pair) $25.00 #107 Impeller Fan (Early or late, all fins intact) $40.00 #108 Heat Flapper valves (L or R) $35.00 #112 Muffler hanger for late 1.8 or 2.0L $9.14 #114 Rear Trailing arm hubs (pair /4) $20.00 #119 F. hood springs (pair) $9.14 #120 Map Pocket (Black) $25.00 #121 1.7L pre-heater tin assembly (rare!) $35.00 #122 Heat vents (Cabin under dash pair) $9.14 #123 Door latch assemblies (Int. pair) $35.00 #124 Door latch assemblies (Ext. per) $9.14 #125 Longitudinal tar long plugs (set of 4) $9.14 #127 OE Trunk spring rollers (plastic) $9.14 #128 R. Tail panel section $60.00 #129 Windshield washer res. bottle (w/lines) $20.00 #130 .5 shafts (pair) $50.00 #131 Tank latch set $15.00 #132 Cabin access cover set $20.00 #133 Motor mount brackets (pair late) $25.00 #134 Fresh air valves (R or L per) $9.14 #135 Defrost Vent (R or L per) $9.14 #138 Targa top complete w/hardware $75.00 #139 Body plug set (front) $30.00 #140 E-Brake handle assembly (late) $45.00 #142 Shift knob, leather & crest $30.00 #143 Exterior Door handles (no lock cyl.) $50.00 #145 Eng. Bay Relay board (average cond.) $25.00 #146 Various Engine tin. per piece. (no 2.0L top) $9.14 #147 Side shift conversion parts (All, no trans-axle) $150.00 #150 Engine Case $75.00 #157 Carpet Pieces (per)$9.14 [s]#158 Dash switch set $55.00 #160 Muffler Heat Shield $30.00 #164 Rebuilt Pedal cluster $125.00 #166 Front suspension PU $35.00 #169 Defrost R. Window Glass $50.00 #171 Formed Glove box (w/strap) $20.00 #172 Engine Windage tray/oil PU $30.00 #174 1.7L D-Jet FI harness $40.00 #175 Eng. Shroud flap assembly $35.00 #176 2.0L Rods (set of 4) $70.00 #177 OE Front steel valance $75.00 #178 Riviera wheels (Porsche offset, per) $30.00 #181 901 gear sets (inquire) $75.00 #182 901 Syncro rings (Good used, per) $30.00 #183 Air injection "spider" pipe $25.00 #185 Drivers door panel (blk.) $50.00 #186 D-Jet Fuel Injection Pkg (76MY) $400.00 #187 Center tunnel section (complete w/all guide tubes intact) $150.00 #188 Late bumpers (75-76) per $40.00 #189 Seat cores (one pair, disassembled & boxed) $50.00 #191 OE Rear steel valance $100.00 #192 Heater fan (eng. bay Late) $30.00 #193 Targa top latches (Frt. & R) $30.00 #194 Air diverter's (eng. bay, pair) $30.00 #195 Washer switch (early /4 & /6) $20.00 #196 Speedometer angle drive $35.00 #197 Fresh air hose (plastic, pair) $20.00 #198 Relay board $25.00 #199 Alternator $40.00 #200 Visors (pair) $80.00 #201 Switch, R. window defrost $20.00 #202 Trailing Arm mounts $35.00 #203 Seat adjuster assemblies (per) $40.00 #204 Fog lights (pair, early) $50.00 #205 Back pad, Black (Avg. cond. ) $60.00 |
Lo-Fi Version | Time is now: 26th June 2024 - 03:39 AM |
