mikea100 |
Member ![]() ![]() Group: Members Posts: 180 Joined: 28-December 09 From: Edison, NJ Member No.: 11,182 Region Association: North East States ![]() |
Yesterday, with some help from my 2 boys, I got my '76 2.0 short block on the engine run stand. I need help setting it up. It's late 2.0, complete, all stock, EFI. I'm looking for any info, any help at all. I've read few dozen threads about engine stands, but most of them deal with yokes, adapters and such. I need help with wiring and actually test running the engine. If local guys can stop by this long weekend and land me a hand, you'd really do me a solid and I'll return the favor. I'll serve beer of your choice. (IMG:style_emoticons/default/beerchug.gif)
Thanks, Mike Attached image(s) ![]() ![]() ![]() ![]() |
mikea100 |
Thanks Dave.
I finally got a compression gauge and did the test. The numbers are pretty bad especialy #1. I'm pretty bummed out about it. The engine hasn't run since 2001, so tomorrow I'll try to adjust valves and repeat the test. I'll also make sure that the throttle wide open. The intake valve is on the left side, correct? #1 - 40psi #2 - 70psi #3 - 70psi #4 - 70psi |
Lo-Fi Version | Time is now: 20th June 2024 - 09:06 AM |
