Testing engine on run stand, Need help with setup |
mikea100 |
Jan 9 2012, 08:28 PM
Member Group: Members Posts: 180 Joined: 28-December 09 From: Edison, NJ Member No.: 11,182 Region Association: North East States |
Yesterday, with some help from my 2 boys, I got my '76 2.0 short block on the engine run stand. I need help setting it up. It's late 2.0, complete, all stock, EFI. I'm looking for any info, any help at all. I've read few dozen threads about engine stands, but most of them deal with yokes, adapters and such. I need help with wiring and actually test running the engine. If local guys can stop by this long weekend and land me a hand, you'd really do me a solid and I'll return the favor. I'll serve beer of your choice. (IMG:style_emoticons/default/beerchug.gif)
Thanks, Mike Attached image(s) |
ruddyboys |
Jan 30 2012, 04:09 PM
Hummel eigentümer Group: Members Posts: 594 Joined: 3-March 04 From: Monroe, NY Member No.: 1,749 Region Association: North East States |
I am going to try this in a few weeks. 1st question, I understand the wiring to the starter, Can I put a lead from the battery (possibly with a toggle sw) to the + post on the coil to give power to the dizzy? The PO removed the relay board so wiring is a nightmare
mikea100 |
Jan 31 2012, 09:35 AM
I am going to try this in a few weeks. 1st question, I understand the wiring to the starter, Can I put a lead from the battery (possibly with a toggle sw) to the + post on the coil to give power to the dizzy? The PO removed the relay board so wiring is a nightmare This is stock wiring of coil for D-Jet (1.7 and 2.0): 1) Green wire connects Condencer to Points to Terminal 1 (-) on Coil 2) Main harness has 2 wires branched out - black and purple. The black one connects to Terminal #15 (+) and the purple wire connects to Terminal 1 (-). You can hot wire battery (+) to Terminal 15 (+). I believe that you MUST disconnect Green and Purple from Terminal 1 (-). IIRC that's how they test ignition switch. |
Lo-Fi Version | Time is now: 20th June 2024 - 09:21 AM |
