> D-jet MegaSquirt&Spark system, Show Stock MSII system in D-jet box
kertwerks
post Aug 24 2011, 06:15 PM
Hello Group,
My name is Kurt and I love 914's and older 912's.
I have a product I've made for my girlfriends Volvo 1800 that might interest some of the members of your list.
I can offer a Megasquirt&spark engine management systems the modifies the D-jet distributor and replaces the FI timing cam and points with a magnetic trigger wheel and hall effect sensor. it dupicate the D-jet system to Show Stock Quality.
An O2 sensor bung in the exhaust and a vacuum line are the only thing to be added to your car.
I've set up an album on my fliker page here is a link:
http://www.flickr.com/photos/kertwerks/set...157627511841022 You can e0mail me of list @ kertwerks@mindspring.com
Kurt
Attached File(s)
Attached File  MegaSquirt_Stealth_Kertwerks.pdf ( 32.94k ) Number of downloads: 1666
bam914
post Feb 5 2012, 07:57 AM
Hey. That's my ECU picture. Yep Bill does awesome work. He did that system for my race 914. That was a fuel only system. It ran flawless.
kertwerks
post Feb 5 2012, 10:38 AM
QUOTE(bam914 @ Feb 5 2012, 06:57 AM) *
Bam,
The system in you car looks good. I don't do anything to the ECU box other then clean the dirt off it as the 1800 guys seem to think the patina'd look of the zinc plated case is more stock looking.
I've worked with a few SDS systems and one of the Volvo guys used to make a similar system with MS I, that was a fuel only system. Did you use the factory dizzy trigger for the FI?.
The biggest problem with the MSII stealth system was getting the timing position of the trigger wheel and sensor in the dizzy alinged properly with the rotor position to the cap.
The earlier systems I built for a track car is likely moving to COP in the near future(another advantage of MSII).
bam914
post Feb 7 2012, 07:31 PM
QUOTE(kertwerks @ Feb 5 2012, 08:38 AM) *
Bam,
Yep. Used the stock distributor with a Pertronix Ignitor. I also had a Mallory Hi-fire box and coil. I used the tach output on the Hi-Fire to trigger the ECU.
kertwerks   D-jet MegaSquirt&Spark system   Aug 24 2011, 06:15 PM
ConeDodger   Kind of like this? Bill has been doing this with S...   Aug 24 2011, 06:20 PM
ConeDodger   cool and innovative though... Lots of Megasquirt g...   Aug 24 2011, 06:21 PM
kg6dxn   What's the price point for the complete 914 sy...   Aug 24 2011, 06:29 PM
kertwerks   Group, Sorry I haven't posted anything on the...   Feb 5 2012, 12:58 AM
kg6dxn   PM Jeff Bowlsby. He is the stock FI harness guru. ...   Feb 5 2012, 01:22 AM
ClayPerrine   Funny, I was thinking about this very same subject...   Feb 5 2012, 07:31 AM
kertwerks   Clay, Why not mount the megasquirt map sensor rem...   Feb 5 2012, 10:24 AM
ClayPerrine   Clay, Why not mount the megasquirt map sensor re...   Feb 5 2012, 07:22 PM
bam914   Hey. That's my ECU picture. Yep Bill does aw...   Feb 5 2012, 07:57 AM
kertwerks   Hey. That's my ECU picture. Yep Bill does a...   Feb 5 2012, 10:38 AM
bam914   Hey. That's my ECU picture. Yep Bill does ...   Feb 7 2012, 07:31 PM
JamesM   With a minor change to the MS injector circuit thi...   Feb 5 2012, 12:42 PM
kertwerks   [quote name='JamesM' date='Feb 5 2012,...   Feb 5 2012, 08:38 PM
JamesM   This is more then a plan I have, I first put MS on...   Feb 6 2012, 11:35 PM
kertwerks   Hello again group, The Megasquirt Stealth System i...   Jun 15 2012, 09:11 AM
JamesM   Can you provide more information on your dizzy set...   Feb 5 2012, 12:49 PM
JamesM   Another thing i did was to wire the MS serial port...   Feb 6 2012, 11:42 PM
kertwerks   James, "To answer your questions though... ...   Feb 7 2012, 12:02 PM
JamesM   Fast idle on the 914 is handled by the Aux. air re...   Feb 7 2012, 11:36 PM
- Lo-Fi Version Time is now: 6th January 2025 - 03:58 PM
