starter relay, next gen modification |
Tom |
Oct 25 2011, 06:31 PM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
Well, been meaning to get this done for a while. Didn't want the hot start kit from Bosche or the Ford relay, so I found one on line that I liked.
Installed the relay on a small bracket on one of the mounting screws for the relay board. Ran a new small yellow wire to pin 6 of the 12 pin connector and a brown ground wire to the bracket . Ran two 12 ga. wires fron the relay to the solenoid with the hot wire having an inline water resistant ATC fuse holder with a 30 amp fuse. Put some heat shrink around the normally used large yellow wire to protect it. On the solenoid side used tape to protect the connector that used to be hooked to the solenoid. This relay uses 140 mili-amp so not a very large inductive spike to worry about, but I installed a supression diode across the relay coil anyway. Also put a larger one across the solenoid coil at the relay ( 87 to ground). This supresses the solenoid coil inductive spike to protect the relay contacts. here are a few pics, and a link to more info: http://www.google.com/url?sa=t&rct=j&a...eg_6KDxZdKYQYGw This is the aeroelectric link Oh, I tested it several times and it works just fine. Tom Edit: changed back EMF to inductive spike, sorry if this confused anyone. Inductive or transient spike is the correct term for what is happening here Attached thumbnail(s) |
Tom |
Feb 9 2012, 06:40 AM
I have been thinking of the next generation of this and want to add a push to start switch so when I need to "bump" the engine over it will be easy to do so from the engine compartment. A rubber cover over the push switch would keep accidental bumps to a minimum.
Tom |
pcar916 |
Feb 9 2012, 08:54 AM
Is that a Lola? Group: Members Posts: 1,523 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None |
... add a push to start switch so when I need to "bump" the engine over ... I have my button on the relay board under the dash and fed directly from the battery. I've never had to use it to get around a bad ignition switch, but had to after a spin at Texas Motor Speedway at Parade in 2004 the switch wouldn't work... the button however, worked like a champ. I don't really want people to be able to see it. Then they might push it and if the car is in gear, which it will be if the car is parked, it's gonna lead to an embarrassing moment, possible an expensive one, |
Lo-Fi Version | Time is now: 6th January 2025 - 05:10 PM |
