Another brake caliper option |
Trekkor |
Feb 3 2012, 11:30 PM
I do things... Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California |
VW Fox.
1988 is what I'm using. Slight grinding required. 50% bigger than stock. (IMG:http://www.914world.com/bbs2/uploads_offsite/i944.photobucket.com-1413-1328333440.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i944.photobucket.com-1413-1328333440.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i944.photobucket.com-1413-1328333440.3.jpg) The calipers are very low priced. KT |
McMark |
Feb 14 2012, 05:16 PM
PN: 002 430 93 01
ATE Number: 03.2123-3402.3 23mm Master Cylinder Mercedes Applications: 450SLC from chassis # 007850 107.024 thru chassis # 011199 107.024 450SL from chassis # 021172 107.044 thru chassis # 028299 107.044 280 thru chassis # 120210 114.060 280C thru chassis # 106627 114.073 RockAuto only seems to list aftermarket or reman units. I can get a new ATE part for $175 if anyone is interested. Also, you'll have to get a little creative for the second reservoir feed line, because IIRC it's too far forward and will run into the chassis. Attached image(s) |
SirAndy |
Feb 14 2012, 05:55 PM
Resident German Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Also, you'll have to get a little creative for the second reservoir feed line, because IIRC it's too far forward and will run into the chassis. (IMG:style_emoticons/default/smash.gif) All you need is a little "dimple" in the sheetmetal to clear the line ... (IMG:style_emoticons/default/shades.gif) |
Lo-Fi Version | Time is now: 26th June 2024 - 03:17 AM |
