Another brake caliper option |
Trekkor |
Feb 3 2012, 11:30 PM
I do things... Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California |
VW Fox.
1988 is what I'm using. Slight grinding required. 50% bigger than stock. (IMG:http://www.914world.com/bbs2/uploads_offsite/i944.photobucket.com-1413-1328333440.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i944.photobucket.com-1413-1328333440.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i944.photobucket.com-1413-1328333440.3.jpg) The calipers are very low priced. KT |
yeahmag |
Feb 14 2012, 06:58 PM
Advanced Member Group: Members Posts: 2,424 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
My understanding after tons and tons of research is that the only thing you get is more pad material with a larger size pad. Friction coefficient doesn't really go up. If it does then you have heat shedding issues.
How has this pad/caliper package worked out for you with regard to heat, fade, and feel? |
Trekkor |
Feb 14 2012, 07:30 PM
My understanding after tons and tons of research is that the only thing you get is more pad material with a larger size pad. Friction coefficient doesn't really go up. If it does then you have heat shedding issues. How has this pad/caliper package worked out for you with regard to heat, fade, and feel? I run Porterfield R4 pads on the Fox calipers in the front and on the stock rears. The stopping power is better than ever. It could use some more rear bias. I still run the stock prop valve so a tee or using another set of Fox fronts as rears with a lesser pad compound should help. These do not fade. I have cool air ducting and run Motul brake fluid. Calipers do not get above 300°. Also, the fact that only the inboard pads contribute to caliper heat soak is nice. Plus the piston bore is in the air stream instead of within the confines of the wheel shell. It's a nice set-up. KT |
Lo-Fi Version | Time is now: 26th June 2024 - 03:31 AM |
