consolidated |
Newbie ![]() Group: Members Posts: 15 Joined: 14-November 11 From: Texas Member No.: 13,781 Region Association: None ![]() |
The 914 Spec series or "H2R Challenge" is starting next week but I feel the car may not be making optimum power. It has dual 40 IDF Webers with stock 155mm main jets, I'm in Austin, Texas 450' elevation.
Any carb and timing tuning advice would be very much appreciated. The motor is s stock 1.7L, rebuilt with new pistons, rings, bearings, crankshaft, seats etc. Compression is good. How much timing advance is optimal for these motors? Thanks! ![]() |
jmill |
Green Hornet ![]() ![]() ![]() ![]() Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest ![]() |
If you stick with the F11 and 28 vents your 115 mains are in the ballpark. You say you are rich on your A/F ratio gauge. At what RPM are you reading this, 3K to redline or above 4K? If your rich above 4K try stepping up your AC jet size. What's your mixture like at transition from idles to mains?
Are you reading the A/F ratio in the driveway or under load? |
Lo-Fi Version | Time is now: 26th June 2024 - 12:13 AM |
