consolidated |
Newbie ![]() Group: Members Posts: 15 Joined: 14-November 11 From: Texas Member No.: 13,781 Region Association: None ![]() |
The 914 Spec series or "H2R Challenge" is starting next week but I feel the car may not be making optimum power. It has dual 40 IDF Webers with stock 155mm main jets, I'm in Austin, Texas 450' elevation.
Any carb and timing tuning advice would be very much appreciated. The motor is s stock 1.7L, rebuilt with new pistons, rings, bearings, crankshaft, seats etc. Compression is good. How much timing advance is optimal for these motors? Thanks! ![]() |
jmill |
Green Hornet ![]() ![]() ![]() ![]() Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest ![]() |
Jetting advice is difficult to give without hearing your engine run, knowing how rich or lean it is and knowing exactly where it stumbles. I can run with the little info I have and give a possible range.
Idle = .50 - .55 Main = 1.20 - 1.25 A/C = 2.10 (maybe 2.20 depending on how rich you were) Buy the Weber Tech manual. I think CB has it for $13. Read it a bunch of times and you'll no longer consider yourself a carb idiot. |
Lo-Fi Version | Time is now: 26th June 2024 - 12:25 AM |
