Fuse block for red wires from batt, EDIT: 3/06/13. not making kits anymore. |
Tom |
Aug 22 2011, 06:54 AM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
EDIT: 3/06/13
I won't be providing these kits any longer. I apologize to the members who have been waiting. Please feel free to use any info in the thread to help you come up with a fuse solution that meets your individual needs. Parts list on last page. Tom NEW INFO FOR EARLY CARS. THEY CAME WITH ONLY THREE RED WIRES!! Two 4.0mm and a much larger wire running forward to the dash area. Please check before ordering. Last round this summer. Maybe next winter I will do this again if there is a demand. See pics of the new 4-way and 6-way kits, and the completed install of mine. Kits are designed to go on the outer edge of the battery box, however some have mounted elsewhere. If you have need for longer wires so you can mount yours differently, let me know and we can make that work for you. Also, please see the two pages of info below. You should be able to print copies. From the supplier: 4/6 individually fused circuits with connections that enter and exit from the bottom allow this fuse block to be mounted in narrow locations. Clear plastic dust cover is included. Max load capacity for all circuits combined is 50 amps, 65 amps for the 6-way. Connections are made using 1/4" female push-on connectors. I will open round four as I already have 3 folks who want one. There will be two models, a 4-way and a 6-way, and three stages; 1-basic, 2-connections on and soldered, 3 - with new battery connector. 4-way stage 1- basic kit $25.00 stage 2- connectors on and soldered and harness heat shrinked $30.00 stage 3- With new battery connector $32.00 6-way stage 1- basic kit $30.00 stage 2- connectors on and soldered and harness heat shrinked $35.00 stage 3- With new battery connector add $37.00 I will leave this open until 5 June, them order parts. It looks from the last round that you can expect about a month to receive the kit. IE: if I order parts by 6 June, the kits will ship no later than 30 June. . Attached thumbnail(s) |
Tom |
Feb 16 2012, 07:31 PM
I have received replies from all except Zymurgist and Somd914 about what style of kit they want and as soon as they let me know, no hurry as I know some are checking their friends, I will order the parts, hopefully not later than 22 Feb. Expect about two weeks to get all of the parts and begin putting kits together. As soon as I get the parts, I will send everyone an address to send either a money order or personal check for payment. If you have any requests for longer wires for a different location, and/or no aluminum mounting plate, let me know and we can make that work for you.
Thanks, Tom |
euro911 |
Feb 17 2012, 12:05 AM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,860 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
... If you have any requests for longer wires for a different location, and/or no aluminum mounting plate, let me know and we can make that work for you. Who in their right mind would order one with longer wires? (IMG:style_emoticons/default/screwy.gif) Thanks, Tom Oh yeah (IMG:style_emoticons/default/laugh.gif) Thanks a lot Tom (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 28th December 2024 - 02:34 AM |
