> V6 & V8 teeners - above/below the axles?, Let's see your exahust!
3d914
post Feb 13 2012, 09:52 PM
Seen a couple different approaches for exhaust on V6 & V8 teeners. Gettin ready to fab a Y-pipe for the SHO motor going into the 914. Want to run single exhaust down the right side, muffler in stock position, and single tail pipe out the back-left.
Curious to see different approaches there are for routing exhaust above or below the axles. Post pics!
Here's a picture of the 3.2L SHO motor.
TIA
matthepcat
post Feb 19 2012, 12:41 AM
Meat Popsicle
Drone is when your exhaust creates a harmonic vibration often changing depending on RPM and engine load. Conversions with "true dual" exhaust routing seem to suffer from an aggressive version of this problem.
Ever ride in a hotrod with no carpet, and 2chamber flow masters that dump at the rear axle?
Drives you crazy on a longer drives.
3d914   V6 & V8 teeners - above/below the axles?   Feb 13 2012, 09:52 PM
pdlightning   Seen a couple different approaches for exhaust on...   Feb 13 2012, 10:38 PM
3d914   Great feedback guys, thanks. Above the axles it is...   Feb 18 2012, 09:37 AM
matthepcat   My 350 used to have one side cross under the oil p...   Feb 13 2012, 11:25 PM
jimkelly   drone - not sure i will ever grow accustomed to it...   Feb 14 2012, 10:21 AM
andys   Over the axles. Andys   Feb 14 2012, 11:06 AM
bulitt   Over the axles. Andys Did you just weld up a b...   Feb 14 2012, 01:07 PM
andys   Over the axles. Andys Did you just weld up a ...   Feb 14 2012, 01:20 PM
slothness   I went over the axles too for maximum lower-abilit...   Feb 14 2012, 11:58 AM
Andyrew   Above the axles is the only way to fly.   Feb 14 2012, 12:06 PM
slothness   Oh and the heat shields in Andys first pic is a re...   Feb 14 2012, 12:13 PM
Andyrew   Muffler shop. 5 years ago they did mine for 300 in...   Feb 14 2012, 01:22 PM
computers4kids   No drone, over the axles and a crossover pipe with...   Feb 14 2012, 10:28 PM
914.SBC   :beer3:   Feb 18 2012, 11:21 AM
TC 914-8   My car now, SBC goes over the axles, never thought...   Feb 18 2012, 06:52 PM
3d914   Thanks for the encouragement. TC - got some pics? ...   Feb 18 2012, 07:49 PM
3d914   Here's the mockup pics for the down pipes from...   Feb 18 2012, 08:01 PM
matthepcat   Good idea using PVC pipe. Also great choice mergin...   Feb 18 2012, 08:03 PM
3d914   matt, can you elaborate on the "drone"?   Feb 18 2012, 10:12 PM
matthepcat   Drone is when your exhaust creates a harmonic vibr...   Feb 19 2012, 12:41 AM
3d914   Wouldn't a cross-over tube help eliminate that...   Feb 19 2012, 05:36 PM
matthepcat   Wouldn't a cross-over tube help eliminate tha...   Feb 20 2012, 12:30 AM
- Lo-Fi Version Time is now: 24th November 2024 - 01:21 AM
