the head |
Newbie ![]() Group: Members Posts: 16 Joined: 8-October 09 From: des moines ia Member No.: 10,906 Region Association: None ![]() |
I have two 1.7 motors
First one Engine ran when we pulled it out last month. Includes Alternator, EMPI Mechanical Advance distributor with bosch red cap and bosch revlimit rotor with pertronix ignition module, new plug wires, air guides (except for alternator panel it was not on the motor when we got it), weltmeister oil pump high pressure upgrade, weltmeister deep oil sump, original taco plate with vdo temp sender installed, vdo oil pressure sender installed in stock location and bosch blue ignition coil. $100 or offer The second one swallowed a valve adjuster screw down the pushrod tube I will sell any parts off this motor or sell the whole thing for has original fi distributor and air guides as well. $50 Engines do not include clutch, flywheel or induction systems PM me for pictures, |
02loftsmoor |
Senior Member ![]() ![]() ![]() Group: Members Posts: 577 Joined: 26-June 11 From: Ft. Worth TX Member No.: 13,243 Region Association: Southwest Region ![]() ![]() |
any bites on the Engines??
I have two 1.7 motors First one Engine ran when we pulled it out last month. Includes Alternator, EMPI Mechanical Advance distributor with bosch red cap and bosch revlimit rotor with pertronix ignition module, new plug wires, air guides (except for alternator panel it was not on the motor when we got it), weltmeister oil pump high pressure upgrade, weltmeister deep oil sump, original taco plate with vdo temp sender installed, vdo oil pressure sender installed in stock location and bosch blue ignition coil. $100 or offer The second one swallowed a valve adjuster screw down the pushrod tube I will sell any parts off this motor or sell the whole thing for has original fi distributor and air guides as well. $50 Engines do not include clutch, flywheel or induction systems PM me for pictures, |
Lo-Fi Version | Time is now: 25th June 2024 - 12:43 AM |
