lmcchesney |
Member ![]() ![]() Group: Members Posts: 488 Joined: 24-November 03 From: Ocala, Fl. Member No.: 1,381 Region Association: None ![]() |
Does anyone remember the post where the blower housing alteration is done to imporve cooling? I recall two air outlets were blocked to imporve flow.
L. McC |
maf914 |
Not a Guru! ![]() ![]() ![]() ![]() Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None ![]() ![]() |
If these are closed off you end up with two square edged pockets on the inside of the shroud schroll which may disturb flow. You could fill these or make covers that match the curve of the schroll. I assume the flow would then be as good as before or increase slightly. Just a guess.
Lo-Fi Version | Time is now: 22nd June 2024 - 09:36 PM |
