TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
73- 2.0L. Flasher unit clicks any time the key is on. Left blinker works fine. Right blinker clicks very fast and blows the fuse. Any ideas as to what would cause this? Combo switch? Seems like lots of electrical problems this week.
aircooledboy |
Sweet Pea's 1st ride in daddy's "vroom -vroom" ![]() ![]() ![]() Group: Members Posts: 1,672 Joined: 4-February 04 From: Rockford, IL Member No.: 1,629 Region Association: Upper MidWest ![]() |
Curt, I had the exact same problem, right down to the blowing fuse symptom. For me, it was an open circuit caused by a broken wire inside the rubber boot where the wiring harness comes out of the fire wall down by where the shifter linkage is.
If all else fails, you might want to try some continuity testing on the tail light related wires, to see if you have an open circuit. Somehow that created the exact same scenario for me that you have described. |
Lo-Fi Version | Time is now: 28th June 2024 - 01:32 PM |
