Testing engine on run stand, Need help with setup |
mikea100 |
Jan 9 2012, 08:28 PM
Member Group: Members Posts: 180 Joined: 28-December 09 From: Edison, NJ Member No.: 11,182 Region Association: North East States |
Yesterday, with some help from my 2 boys, I got my '76 2.0 short block on the engine run stand. I need help setting it up. It's late 2.0, complete, all stock, EFI. I'm looking for any info, any help at all. I've read few dozen threads about engine stands, but most of them deal with yokes, adapters and such. I need help with wiring and actually test running the engine. If local guys can stop by this long weekend and land me a hand, you'd really do me a solid and I'll return the favor. I'll serve beer of your choice. (IMG:style_emoticons/default/beerchug.gif)
Thanks, Mike Attached image(s) |
Tom |
Feb 25 2012, 10:57 AM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
Did you hook up your relay board? That is needed to tell the fuel pump when to turn on and the ECU power comes from the relay board.
If possible, give us a simple drawing of what you have now and we can get you in the right direction. Common problem when testing like this is too small of a ground wire to battery. Need something large! If you have a good set of jumper cables, use one of them from batt negative to trans case. Tom |
Lo-Fi Version | Time is now: 21st September 2024 - 10:03 PM |
