tadink |
Member ![]() ![]() Group: Members Posts: 379 Joined: 28-December 09 From: Napa Member No.: 11,181 Region Association: Northern California ![]() |
uh oh - I'm trying to figure out what vacuum tubes go where and my reality does not match the schematic, and worse, it appears that someone may have gotten creative.
In the pix below - I don't know what the 'Y' is, and it appears that in the second pic there has been some rubber goop poured around the fitting. From the Y - one hose goes immediately to the fitting nearby - the other travels around the engine bay - thru the thing in pic3, and back to the 'customized' fitting with the rubber goop on it. have a look a the pix and see if you can tell what is going on here....please. thanks all td Attached image(s) ![]() ![]() ![]() |
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
Sorry, AAR = auxiliary air regulator. It lets in air when cold and cuts off extra air when warm. Just make sure all the fittings are tight and no leaks and it wont be the cause of your next problem.
Lo-Fi Version | Time is now: 25th June 2024 - 12:58 AM |
