Primer Question, Prime now, drive, paint later. |
ruby914 |
Feb 26 2012, 02:47 PM
Senior Member Group: Members Posts: 720 Joined: 26-April 09 From: Hawthorne, Ca Member No.: 10,305 Region Association: None |
OK, I have my flares on.
I am fumbling through the clean up body work that goes with that and finding other body work that is needed as I go. Cass Nawrocki's book has already helped. The thing is, this car is one of my (2) 914 DDs In order for me to get clean lines on the body I need to remove the last 3, 4, 5 or 6 paint jobs. I have some 5 Star 5425 X Treme 2K Direct to metal Primer Filler/ Sealer. After I go down to the metal and spray with the sealer mix ratio, can I trust this to drive the car? Even park out side in the moist air, in the rain??? Then paint later, 6 months, 1 year later ?? What can I get away with? (IMG:style_emoticons/default/confused24.gif) Attached thumbnail(s) |
underthetire |
Feb 26 2012, 02:56 PM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
Rust will form through primer faster than you think. Then there is the problem with grease and road grime on the fresh primer. Can you, sure, but it's gonna be more work later.
Lo-Fi Version | Time is now: 26th June 2024 - 02:33 PM |
