euro911 |
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California ![]() ![]() |
I just purchased a new 1844 'Ignitor' module. I read the instructions and installed it in the distributor.
I attempted to test the module with a Fluke VOM to verify it provides a pulse. I get a continuous reading of .2387 meg-ohms and the value does not change when the shaft is rotated by hand (yes, magnetic trigger ring is completely seated on the cam shaft). Does the module require 12vDC to see a pulse? ... or is it possible that this module is defective out of the box? (IMG:style_emoticons/default/confused24.gif) ![]() |
Tom |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None ![]() |
I am certainly no expert, but points work just the opposite of what that test would indicate. You are basically measuring across the switch for voltage/no voltage. With the switch closed = no voltage, switch open = voltage.
When the rotor opens the points you would read voltage and that is when the coil fires. This test would indicate just the opposite.?? Tom http://www.google.com/url?sa=t&rct=j&a...BkzppF8B3AYlg3A Edit: googling found this. |
Lo-Fi Version | Time is now: 24th June 2024 - 07:00 AM |
