Tom_T |
TMI.... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California ![]() ![]() |
I seem to recall somebody posting here that they'd taken their 928 to some 914 or P-car events over the past year, so I think there are some closet Shark fans out there! (IMG:style_emoticons/default/biggrin.gif)
I just don't recall who it was, or if there are several?? I have a crazy question which I posted over at the Pelican 928 Forum about whether you could tow with a 928, so any shark lovers here could maybe answer over there: http://forums.pelicanparts.com/porsche-928...tml#post6595065 Otherwise, if you prefer I'll just post it here too, but I didn't want to clutter up a 914 site with 928 questions, and risk being kicked to the sandbox again! (IMG:style_emoticons/default/dry.gif) TIA (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
jim912928 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,485 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest ![]() |
I don't believe there was any direct change of wiring to deal with issues. 928's get tagged by a lot of folks as having electrical gremlins (mine never did)...but the real issue was in the massive amount of advanced (for the time) montiors and electronics. Just about everything is monitored in 928's (turn on the ignition and it looks like a space ship lighting up with all the diagnostic lights). Due to that it has a lot of wiring, a lot of relays and dual analog computers. How many 80's cars will tell you on the dash that you have a back light out? With more electronics just comes more issues when something arises. The problems come into play when folks try to fix things themselves. As I said above mine was a daily driver for years...and it NEVER once left me stranded. Only maintenance I did was normal fluid changes, timing belt (although the 16V non-euro engines are not interference...just never wanted to be stranded), water pump (only because I was in there to change the belt), wheel alignments and plugs.
86.5 model years started bringing in the 32V engines which are interference...thus you get a lot more diligence on timing belt changes...cheap insurance. I'm not sure, but I believe around 85/86 they changed the air conditioning system (which would draw more power and push for a bigger alt) to have a rear unit that was mounted between the rear seats vs. the luggage compartment that was optionally there. This did deal with an issue of heat due to that massive rear window. They also started, around that time, bringing in more digital electronics on the dash versus the analog setups...more modern looks but, again, power draws which had them amp up stuff. Sharks are great cars and like any Porsche will cost more to repair...but what upscale car doesn't cost more to maintain? It's a dependable super cruiser that you can get pretty cheap relative to their original costs. One thing to note when you test drive one...the automatics start from a dead stop in 2nd gear. So if you are looking for that neck snapping start you either have to floor it (the gas pedal will hit a mechanical switch that will drop the tranny down into 1st) or manually shift it. The design here is for smooth comfortable cruising...thus they started it out in 2nd. It's a beast when you drop it in 1st. It's also a rocket ship from about 70 to 140! |
Lo-Fi Version | Time is now: 26th June 2024 - 09:09 AM |
