> Shrinkage. (no pool content), actually...panel shrinkage--gap issues
TargaToy
post Mar 3 2012, 08:13 AM
-NONSOLIS RADIOS SEDIOUIS FULMINA MITTO-
Rick's recent posts where he expertly repaired a previously filled dent in his green car's fender prompted me to post this question. I'm working on the same part of my car but didn't want to hijack his post.
Speaking of beating down the hight spots, this is what was under the filler:
I cut out the whole bad section and reworked the same section I had in a salvaged fender.
As you can see, I cut out the old section right along the top edge of the quarter panel. The cut line was only about 3/16" from the channel for the trunk weather-stripping.
In retrospect, I may have made a booboo here. I thought I took my sweet time welding in this panel but now that everything's said and done (and cooled off), the shrinkage in the panel has pulled the trunk lid gap a bit.
Rick, you once told me that if the gaps were within 3mm (3 dimes) not to stress as the bodies were hand built. However, I'm not thrilled with the trunk gap now and and my finish grinding is not even done yet which means there'll be more heat introduced.
Can this be corrected?
Also, my vertical weld where the two panels join also shrank a bit. Can I use some dolly work and bumping to bring the area out once I do my finish grinding and minimize the amount of filler that'll be needed?
GeorgeRud
post Mar 3 2012, 10:04 AM
Does anyone use lead anymore to do final fitting on gaps such as these? I thought that was the way door gaps were finalized in the old 356 days.
TargaToy   Shrinkage. (no pool content)   Mar 3 2012, 08:13 AM
rick 918-S   No no.. The 3mm tolerance I was refering to is for...   Mar 3 2012, 09:59 AM
GeorgeRud   Does anyone use lead anymore to do final fitting o...   Mar 3 2012, 10:04 AM
rick 918-S   Does anyone use lead anymore to do final fitting ...   Mar 3 2012, 10:13 AM
rudedude   Rick, Kind of off this topic but closely related, ...   Mar 3 2012, 10:41 AM
rick 918-S   Rick, Kind of off this topic but closely related,...   Mar 3 2012, 11:42 AM
TargaToy   Hey, Rick. Thanks as always for the (free) expert...   Mar 4 2012, 08:49 PM
rick 918-S   I think my rear lid is like that. Is the passenger...   Mar 4 2012, 09:04 PM
TargaToy   I think my rear lid is like that. Is the passenge...   Mar 4 2012, 09:16 PM
rick 918-S   I think my rear lid is like that. Is the passeng...   Mar 4 2012, 09:37 PM
TargaToy   Examine the inner panel on the driver side and b...   Mar 6 2012, 08:50 PM
rick 918-S   Examine the inner panel on the driver side and ...   Mar 6 2012, 09:41 PM
914itis   I think my rear lid is like that. Is the passenge...   Jun 11 2012, 09:24 PM
rick 918-S   Make sure your tail light fits also.   Mar 4 2012, 09:07 PM
TargaToy   Here's an update...and I'd like to add tha...   Jun 9 2012, 06:58 AM
FourBlades   Nice save! :Qarl: Thanks for posting the wh...   Jun 9 2012, 07:05 AM
kg6dxn   Have you test fit the tail lamp yet?   Jun 9 2012, 08:01 AM
TargaToy   Have you test fit the tail lamp yet? Yes. I ha...   Jun 9 2012, 10:31 AM
rick 918-S   Review this thread again. http://www.914world.co...   Jun 11 2012, 08:47 PM
TargaToy   Thanks, Rick. So when I'm working the dolly u...   Jun 11 2012, 09:11 PM
rick 918-S   Thanks, Rick. So when I'm working the dolly ...   Jun 11 2012, 09:20 PM
TargaToy   Got it. Thanks again.   Jun 11 2012, 09:24 PM
rick 918-S   Send me a pm when you post progress photos again. ...   Jun 11 2012, 09:43 PM
11 User(s) are reading this topic (11 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 25th November 2024 - 11:56 AM
