Shrinkage. (no pool content), actually...panel shrinkage--gap issues |
TargaToy |
Mar 3 2012, 08:13 AM
-NONSOLIS RADIOS SEDIOUIS FULMINA MITTO- Group: Members Posts: 705 Joined: 26-March 10 From: DelMarVa Peninsula Member No.: 11,509 Region Association: MidAtlantic Region |
Rick's recent posts where he expertly repaired a previously filled dent in his green car's fender prompted me to post this question. I'm working on the same part of my car but didn't want to hijack his post.
Speaking of beating down the hight spots, this is what was under the filler: I cut out the whole bad section and reworked the same section I had in a salvaged fender. As you can see, I cut out the old section right along the top edge of the quarter panel. The cut line was only about 3/16" from the channel for the trunk weather-stripping. In retrospect, I may have made a booboo here. I thought I took my sweet time welding in this panel but now that everything's said and done (and cooled off), the shrinkage in the panel has pulled the trunk lid gap a bit. Rick, you once told me that if the gaps were within 3mm (3 dimes) not to stress as the bodies were hand built. However, I'm not thrilled with the trunk gap now and and my finish grinding is not even done yet which means there'll be more heat introduced. Can this be corrected? Also, my vertical weld where the two panels join also shrank a bit. Can I use some dolly work and bumping to bring the area out once I do my finish grinding and minimize the amount of filler that'll be needed? |
GeorgeRud |
Mar 3 2012, 10:04 AM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
Does anyone use lead anymore to do final fitting on gaps such as these? I thought that was the way door gaps were finalized in the old 356 days.
rick 918-S |
Mar 3 2012, 10:13 AM
Hey nice rack! -Celette Group: Members Posts: 20,785 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Does anyone use lead anymore to do final fitting on gaps such as these? I thought that was the way door gaps were finalized in the old 356 days. Yep, 356's but the panel fits were not good to begin with. 914's have pretty good panel fit to begin with, with the exception of the rear lids. It's a large opening with no real defining cowl line to build off of. |
Lo-Fi Version | Time is now: 25th November 2024 - 11:44 AM |
