toadman |
Member ![]() ![]() Group: Members Posts: 168 Joined: 26-December 05 From: Cincinnati, OH Member No.: 5,316 ![]() |
I would like to find a fairly quick way to jack up the back of my 1976 914 higher than most common floor jacks allow. I am considering using a long frame, high lift jack to lift on the center of the engine support bar.
First I would back on to a pair of car ramps. I think this would get me the clearance I need to put the jack under the support bar (from the rear of the car) and to get a little room to pump the handle. I'd jack the back of the car up and properly support it. Has anyone tried this or have an educated guess whether or not the engine support bar can handle the load? Any other opinion on this idea? |
mikea100 |
Member ![]() ![]() Group: Members Posts: 180 Joined: 28-December 09 From: Edison, NJ Member No.: 11,182 Region Association: North East States ![]() |
Check out this thread
http://www.914world.com/bbs2/index.php?sho...=152800&hl= |
rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,579 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
I've used the cast iron side shift bar for 30 years with no problem. If the car has any real rust better check the sheet metal on the body side of the motor mounts for weakness and rust through. Lifting the car this way is also a good indicator of longs weakness. Before going too high check for change in rear door gaps. Opening up big time ?..... stop right there, consult wallet. Also don't go forward under the floor pan, The floor is not strong enough forward of the bulkhead. At the centerline of the jack points you are at the tipping point of the car. It turns into a see-saw. |
rwilner |
No Ghosts in the Machine ![]() ![]() ![]() Group: Members Posts: 953 Joined: 30-March 10 From: Boston, MA Member No.: 11,530 Region Association: North East States ![]() |
I have a 73 sideshift. I have a low profile floor jack from hf and use the engine mount bar to jack up my car...ever since I saw rory do it. I have done this 20 times at least since with no issues.
Go for it. |
Lo-Fi Version | Time is now: 25th June 2024 - 06:23 PM |
