tscrihfield |
Drive Fast and Take Chances ![]() ![]() ![]() Group: Members Posts: 643 Joined: 8-September 10 From: Amelia Ohio Member No.: 12,156 Region Association: None ![]() ![]() |
The units that Quaife sell for the 914. Does anyone know if they are torque bias or if they are a true Limited slip. This is for racing use and I would like to know if it works in deceleration as well as acceleration. Any information would be greatly appreciated.
Thanks, Thomas |
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,643 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
its a tb diff
there is some reason to believe that a tb may be faster than a clutch limited slip in a lower powered mid engine car I've run locked and TB both I can't beat my track time either way, although the TB is much easier to drive and the locked is better in braking.... but its easy to blow it also and harder on tires (constantly sliding) my builder who is an amazing 914 driver swears that they have cut 2 seconds a lap in back to back tests with the TB over the Limited slip driving styles are completely different guard makes both we had a conversation with paul once and he agreed that a TB may be faster in a mid engined car the locked diff is generally preferred above 300hp (500 especially optimum) my belief is that the lower the hp the more the car would work with the TB. not sure where the exact lines should be drawn... but an opinion is that around 225 would probably swing towards a clutch limited slip another thing I considered when choosing my tb over the clutch ls was maintenance. The clutch packs need to be rebuilt regularly both also create much more heat than open or locked. brant |
Lo-Fi Version | Time is now: 25th June 2024 - 08:56 PM |
